Density of Object & Oil: Find Out Now!
  • Thread starter Thread starter Leo34005
    Density Oil
The object weighs 285 N in air, 230 N in water, and 261 N in oil. The buoyant force in water is calculated as 55 N, leading to a density of the object of 5.18. The buoyant force in oil is 24 N, resulting in an oil density calculation of 0.436 times that of water. Participants confirm the answers but emphasize the importance of including units in the calculations. Clarity on unit requirements may resolve any confusion regarding the results.
Leo34005
An object weighs 285 N in the air. When tied to a string, connected to a balance, and immersed in water, it weighs 230 N. When it is immersed in oil, it weighs 261 N.
(a) Find the density of the object.
(b) Find the density of the oil.
A=mgd(water)
this weight is equal to 285-230=55N corresponding to a density =1
so the density of the body is 285/55=5.18
the weight of oil is 285-261= 24 =Mgd(oil)
compared to water d(oil)/d(water)=24/55=0.436
Your answers are correct, but you should write down the units.
I believe my answer is wrong. If someone would double check it.
I did double check it when I first posted. Your answers are right but missing units. If your teacher wanted different units then perhaps therein lies your confusion.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
