Fluid's temperature change in time.
The discussion revolves around a homework problem involving the temperature change of a fluid in a container with a specific volume and heat capacity. The fluid's viscosity decreases linearly with temperature, and it is initially at temperature T0, while a pipe introduces fluid at temperature Tin. The user attempts to derive the time at which the container's temperature reaches a specific value T, using equations related to mass flow and heat transfer. Concerns are raised about the accuracy of the equations used, particularly regarding the definition of parameters and the dependence of mass on time. The final solution is deemed correct, but suggestions are made to clarify variable definitions and to express the answer without using the mean residence time τ0.
peripatein
Hello,
The volume of the container in the attachment is given as V. The container is filled with a fluid whose heat capacity is C and whose viscosity decreases linearly with the temperature.
The fluid is initially at temperature T0, and a pipe carries fluid at temperature Tin into it and at a rate which is equal to the rate of the volume lost from the container (i.e. its dV/dt). I am asked to find the time at which the temperature in the container will be T.
M/V = ρ
m(t) = ρVt/τ0, where m(t) denotes the mass of water which passed through the pipe after time t.
dQ/dt = [ρV/τ0]*Cw(T(t) - Tc) = ρVCwdT/dt
Hence, dT/dt = (Tc - T(t))/T0
Hence, T(t) = Tc + (TH - Tc)e-t/τ0 = Tin + (T0 - Tin)e-t/τ0
t = -τ0ln((T - Tin)/(T0 - Tin))
Is that correct?
Well, the final answer looks right, but, astonishingly, some of the equations leading up to the final answer don't look right. If τ0 is the mean residence time in the tank, then the equation for m(t) should not contain a t, and m(t) itself should not be a function of t. Your equations contain a Tc, but nowhere is this parameter defined. It would appear that Tc is the same as Tin, but I can't understand why you deemed it necessary to introduce another parameter name. Otherwise, OK.
Supposing I wished to express that answer without tau_0, how could I do so granted that the volume of the tank is V?
τ0 = ρV/m, so just substitute that into your solution.
