Flux density of solenoid beyond the pole
To calculate the force exerted by a solenoid on an object at a distance, the magnetic flux density (B) must be determined outside the solenoid. The equation B=(μNI)/L is applicable at the center but may not accurately represent the field beyond the solenoid's ends. The user expresses confusion about the cancellation of length (L) in the equations for force (F=BIL) and magnetic flux density. Reference material was provided to clarify the axial field of a solenoid beyond its coil. Understanding the correct equations is essential for accurately determining the force exerted by the solenoid.
Jake110
I’m making a solenoid and I’m trying to work out how much force it exerts on an object X meters away from it. I’m using F=BIL to get the force but I don’t know the equation for getting the magnetic flux density of the solenoid other than B=(uNI)/L but that’s just for the centre and I need it for outside the solenoid but in line for the object to get pulled towards one of the poles.
Although I’m not sure if B=(uNI)/L is the right equation because the L in that and the L in F=BIL will cancel out when putting them together and it doesn't make sense if the length of the solenoid has no effect on the force it exerts.
yes, that is exactly what i was looking for, thank you.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
