Flux integral is equal to zero
mathwizeguy
If s is a unit sphere, centered on the origin and oriented outward, and the flux integral is eual to zero, does F=0?
Not necessarily. Think for a bit and you should be able to come up with some simple examples of vector fields where the flux through different parts cancels out when you integrate it over the whole surface.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
