Flux vs Power Query - Explained
  • Thread starter Thread starter lavster
    Flux Power
Flux is defined as the amount flowing through a unit area per unit time, and in the context of light bulbs, the flux of photons is related to power, which is energy per unit time. The energy of photons is calculated using the formula E = hf, where h is Planck's constant and f is the frequency. The discussion clarifies that while flux can be measured per unit area, it can also be expressed in different contexts such as per solid angle or as total flux. Understanding the context is crucial for interpreting the dimensions correctly. The relationship between photon energy and flux is essential for grasping how light output correlates with power.
lavster
Hi,
my understanding of flux is that it is the amount that flows through per unit area per unit time. with this in mind, why is the flux (of photons I am assuming) from a light bulb equal to the power, which is the energy per unit time?
Thanks
Because energy is directly related to the number of photons. The energy of one photon is E(of one photon) = hf. So for 2 photons, E(of 2 photons) = 2hf, and so on. (f is the frequency of the photon)
www.gentec-eo.com
thanks :) however it says nothing about the area? is it not meant to b per unit area? so the dimensions are wrong?
You can have flux per area, flux per solid angle, and total flux. You really have to look at the context to figure out which one it is.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
