Flywheel storing kinetic energy
The discussion centers on calculating the maximum kinetic energy (KE) that can be stored in a flywheel with a diameter of 2.30 m and a mass of 75.0 kg, given a maximum radial acceleration of 3430 m/s². The participants clarify that the radial acceleration refers to centripetal acceleration, leading to the relationship a_c = r(ω)². By substituting the maximum acceleration into this equation, they determine the maximum angular velocity (ω_max) to be approximately 54.61 rad/s. Using this value, they calculate the maximum KE to be about 73950.53 J, confirming the importance of understanding the distinction between radial and rotational acceleration in this context. The conversation highlights the structural limits of flywheels due to internal forces and stresses.
QuarkCharmer
There is a 2.30 m diameter flywheel, with a mass of 75.0 kg. For safety/structural (or whatever) reasons, the acceleration at a point on it's rim cannot exceed 3430 m/s^2.
What is the max KE that can be stored in the flywheel?
KE = \frac{1}{2}Iω^{2}
I = kmr^{2}
The constant k, for a solid uniform disk is \frac{1}{2}
KE = \frac{1}{4}(75.0)(1.15^{2})ω^{2}I'm not sure how to go about getting this in terms of radial acceleration?
I was thinking that I could somehow use the relationship that linear acceleration (a) = radial acceleration (α) times the radius.
a = αr
But that is not panning out at all. Can someone give me some direction please?
Hint: What causes a flywheel to fail? Flywheels are generally heavy so they do not accelerate angularly at a high rate. So what else is there?
You need Fc = ma = mv²/r
I think one can assume that the angular velocity is constant. Then a point on its rim will have no tangential acceleration but only centripetal acceleration.
Then one can use v = r x omega
Hint: What's the centripetal acceleration at the outer edge of the flywheel? There's a neat formula for it.
I don't see how to use that in this situation. I don't know the centripital force, or the linear velocity, nor do I understand how to get the maximum kinetic energy out of the equation, or substitute that into the formula for the radial kinetic energy?
But you certainly know the maximum acceleration which is in what direction?
Oh, wait. The acceleration is in m/s^2, by "radial" they are talking about the centripital acceleration, not the "rotational acceleration (rad/s^2). So:
a_{c}=\frac{v^{2}}{r}
v = ωr
a_{c} = \frac{(ωr)^{2}}{r}
a_{c} = r(ω)^{2}
3430 = (1.15)ω^{2}
\frac{3430}{1.15} = ω^{2}
ω_{max} = 54.61
Now:
KE_{max} = \frac{1}{2}Iω^{2}
KE_{max} = \frac{1}{2}I(54.61)^{2}
I = 0.5(75)(1.15)^{2} = 49.59375
KE_{max} = \frac{1}{2}(49.59375)(54.61)^{2}
KE_{max} = 73950.53 J
Does that make sense?
What you did makes sense. I did not check your value for I but using your value for I in my equations, I get essentially the same answer.
Flywheels fail because the internal forces (which are due to centripital forces) cause stresses that exceed what the material can withstand.
Great, thanks! I am sure that my I value is correct, I pulled it from the tables.
Appreciate the help, I can't believe I didn't catch that they were not talking about rotational acceleration.
