Flywheel -- Why does it reverse direction after spinning to a stop?
The discussion centers on the behavior of flywheels, specifically why they reverse direction after coming to a stop due to friction. Participants highlight that the flywheel's mass distribution, particularly when concentrated in the rim, affects its rotational dynamics. The phenomenon is attributed to friction recoil in the axle, which releases remaining energy in counter-rotation once the momentum falls below the friction threshold. The conversation emphasizes that this behavior occurs regardless of external factors like string and weight, and is inherent to the mechanics of spinning objects.
  • Understanding of rotational dynamics and inertia
  • Familiarity with friction and its effects on motion
  • Basic knowledge of flywheel design and function
  • Concept of mass distribution in rotating systems
  • Research "flywheel energy storage systems" for practical applications
  • Explore "friction in mechanical systems" to understand its impact on motion
  • Study "rotational motion equations" for deeper insights into dynamics
  • Investigate "vibration analysis in rotating machinery" to mitigate undesired effects
Engineers, physics students, and anyone interested in mechanical design and dynamics will benefit from this discussion, particularly those focusing on energy storage and rotational systems.
Muhammad Uthman
Why does fly wheel return in opposite motion after it comes to rest due to friction?
Wind-up in the power train.
If most of the mass is in the rim and friction acts at the hub then I guess there might be stress in the spokes if it decelerates rapidly?
Rim? Hub? Spokes?
I was thinking more in accumulated shaft lengths, pedestals, frames, linkages.
Muhammad Uthman said:
Rim? Hub? Spokes?
My flywheel looks like a bicycle wheel with disc brake. What does yours look like?
Understood.
http://www.naugralabequipments.com/images/product/14692275775-250x250.jpg
The one in my Physics lab looks like this one.
Can you describe what happens? For example is the string and weight still attached when it stops and goes backwards?
String and weight falls and it continues to rotate until comes to rest and rotates in opposite direction.
What happens when you run out of string? I'm guessing the flywheel continues spinning and the string remains attached?
Is it winding the string and weight back up?
Nope!
It happens the same if there is no string and we just give is a slight push by hand.
Friction recoil in the axle. Can't seem to find any links about it.
I would imagine if it was very hard to turn, not from the weight itself but from the axle not wanting to turn, like a bicycle wheel with stiff bearings, it would be "springy" if you tried to turn it. When you do apply enough force to turn the wheel that extra force remains counter to the direction of rotation. As the energy left in the momentum dwindles below the friction threshold, the remaining energy is released in counter-rotation. Similar to if you apply less force to the wheel than it takes to turn the axle and release.
If it wasn't perfectly symmetrical it would want to turn until the heavy spot was downwards, and sometimes this will entail reversal of its rotation at the end, but not always. A handful of trials should discount this as the source.
So you have removed all of the string? Is it fixed to the shaft by a knot wedged into a slot, or how?
There also has to be some room in between the axle and the bushing where the axle can "walk up" the inner circumference of the bushing.
A flywheel with this trait would have - let's say ... undesirable side effects.[EDIT] ohhhh. This is a high school flywheel. I was imagining a 10kg flywheel rotating at 30,000 rpms, developing a slight ... wibbly-wobble.
I was picturing the slot in the shaft for the string end would always like to end up uppermost, if all else were ideal.
Every flywheel of this type does so.
What type of flywheel do you mean?
Almost anything that spins does it, more so with greater resistance.
It happens always, so there is nothing like unequal distribution of mass.
And string has nothing to do with it.
String is just in this pic I found at Google Images.
Every spin returns?
Today I learned about "chat-bots", I'm getting the opinion this is not a serious question.:rolleyes:
at the bottom of the weights journey the string is wound back up in the opposite direction
Why does it reverse direction after spinning to a stop? Why does fly wheel return in opposite motion after it comes to rest due to friction?
With all the guesses being denied as correct solutions, I have never in my personnel life had a flywheel do what you seem to be suggesting.
Thanks for putting a picture in your profile, it's a help:) I am interested in the question.
Swing a door partially closed or open it does the same thing. It springs back just a slight bit. Probably less if it had bearings... but its just a stiff hinge friction recoil.
The image was an example, the string and weight have to be removed.
  • · Replies 60 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 37 ·
  • · Replies 37 ·
