Folium of Descartes - very interesting
  • Thread starter Thread starter danni7070
    Interesting
danni7070
This is my problem:
1) Suppose that the function y = f(x) satisfies the equation x^3+y^3 = 3xy and is differentiable.
Find a formula for the derivative y' showing it dependent on x and y.
Well, I really don't know what to do but here goes...
Is it y' = f'(x) = x^3+y^3 = 3xy
Then i have to isolate y (for example y^3) and then derive?
That gives me y = 3sqrt(3xy-x3) and I should derive that formula right ?
If I'm right about this I'm still stuck in problem two which is:
2= Show that for t is not −1 and t is not 0 the line y = tx intersects the folium of Descartes in exactly one point different from (0, 0), and find that point.
I'm clueless now.
Anyone ?
well as i understood it you only need to take the derivataive wrt to x of the equation:
x^3+y^3=3xy and then isolate the y' from the other terms.
what does wrt to x mean? (English is not my first language)
danni7070 said:
This is my problem:
This makes no sensef'(x) is NOT equal to x^3+ y^3!
You could but you don't have to. Use "implicit differentiation" instead.
If x^3+ y^3= 3xy, you have d(x^3+ y^3)/dx= d(3xy)/dx. Since you do not know y as a function of x, use the chain rule: d(y^3)/dx= 3y^2 dy/dx.
I'm clueless now.
Anyone ?
You have two simultaneous equations: x^3+ y^3= 3xy and y= tx. Putting the second equation into the first, x^3+ t^4x^3= 3t x^2. Obviously x= 0 satisfies that. What other solutions (x as a function of t) does that have?
with respect to
OK! Thanks for the advice!
I used "implicit differ" and found out that y' = -x^2/y^2 (The first time I use this method)
But in the second problem I know that x=0 satisfies the equation. But there is on other number that also satisfies that equation, but I don't know how to solve the other point for x.
There is a problem here: that is not the correct result for y' (or dy/dx).
The result y = 3sqrt(3xy-x3) is also not a correct derivation from the original expression for the folium, x^3+y^3 = 3xy . (This would have to involve *cube* roots and is a mess to rewrite as y = f(x). That is why we suggest implicit differentiation.)
HallsofIvy suggested that you start with your original expression
x^3+y^3 = 3xy
and then take the derivative of each side with respect to x:
d/dx [(x^3+ y^3)] = d/dx (3xy) .
You will need to use the Chain Rule; since we don't really know how to write y as a function of x, we just differentiate it, knowing that it has a relation to x. HofI gave you one equation for dealing with the (y^3) term:
d/dx (y^3) = (3y^2) dy/dx = 3(y^2)·y' .
You will also need to use the Product Rule and Chain Rule to find d/dx (3xy). You will then have an equation with a (dy/dx) or y' factor on each side. You will need to rearrange the equation so that you can solve for y'. What do you find?
By the way, it is a good idea to show your work, so the readers here can see how you are getting your results.
HofI also suggested substituting y with tx (the equation given in the problem) in your equation for the folium, giving
x^3 + (tx)^3 = 3·x·(tx) or
(x^3) + (t^3)(x^3) = 3t·(x^2)
[typo in earlier post corrected]
Since we already found x = 0 as a solution, we now want to look at the solution for x when x is *not* zero. How does your result explain why the problem said we cannot have t = 0 or t = -1 ?
Ok, before I type this I must say big thanks for taking your time helping me! It is very helpful.
I've got from part 1:
d/dx(x^3+y^3) = d/dx(3xy) (I will say from now d/dx = y')
Used the product rule on the right side and got (3x)'(y)+(3x)(y)' = 3y + 3xy'
From the left side I got 3x^2+3y^2y'
That does 3x^2+3y^2y' = 3y + 3xy'
I'm not good at this but here goes...
I take the 3xy' from right to left and combine that with 3y^2y':
(3y^2+3x)y' = 3y-3x^2
and then isolate y':
y' = (3y-3x^2)/(3y^2+3x)
take the 3's and the ^ thingies (don't know the english word for ^)
y' = (1-x)/(y-1)
Is this right ?
And from the part 2
Well if t = 0 we have x^3 = 0 and since x has to be something else but zero this doesn't add up.
If t = -1 we have x^3 - x^3 = -3(x^2)
Obviously doesn't fit for x *not* zero.
So t can be every number but -1 and 0 but what about x?
You're OK to here.
Watch your signs: that should be (3y^2 - 3x)y' , so you'll have
y' = (3y - 3x^2)/(3y^2 - 3x)
The " ^ " is called a caret or a circumflex. In mathematical use, we'd read that as "to the power of"; because of that, some people call this the "uppen" symbol... ^_^
You can cancel out the 3's, but the powers of x and y can't just be removed. Your result will be
y' = [ y - (x^2) ]/[ (y^2) - x ] ;
that's as simple as it's going to get. But it also answers the question as to why dy/dx depends on both x and y.
And from the part 2
You still need to solve this:
for x (as a function of t). If x is not zero, what does this reduce to?
