Follow up on the 2 spheres capacitor problem. Help needed before tomorrow
  • Thread starter Thread starter Lisa...
    Capacitor Spheres
The discussion focuses on calculating the capacitance of two isolated conducting spheres with charges +Q and -Q, separated by a large distance compared to their radius. The user initially derives the potential difference using Coulomb's law and integrates the electric field, but encounters an issue resulting in a capacitance of zero, which is not feasible. Suggestions include using a Taylor expansion to approximate the capacitance, leading to a revised formula that incorporates terms for both R and L. The conversation emphasizes careful bookkeeping in calculations and the significance of the potential difference in determining capacitance. The final consensus suggests that the Taylor expansion approach is valid for resolving the problem.
Lisa...
Follow up on the 2 spheres capacitor problem. Help needed before tomorrow!
It was probably a bit hard to see what the old topic was about, so I started a new one. I'm still not quite sure on this problem, so I'd REALLY appreciate it if somebody could clear things up a little bit more. The problem is the following one:
Two isolated conducting spheres of equal radius have charges +Q (#1)and -Q (#2) respectively. If they are separated by a large distance compared to their radius, what is the capacitance of this unusual capacitor?
I've drawn this picture:
http://img147.imageshack.us/img147/7725/naamloos6ha.gif
The origin is in the center of the left sphere.
This is what I've found till now:
C= \frac{Q}{V}
In this case Q= Q = the absolute charge on every sphere.
V= the potential difference between #1 and #2, given by V= - \int_{#1}^{#2} E dl = = \int_{#2}^{#1} E dl
with dl= dxi +dyj+dzk
The electric field due both spheres is determined by Coulombs law (E= \frac{kQ}{r^2}).
Pick a point at a distance r from the origin somewhere on the drawn x-axis. In that point the E field of #1 and #2 is felt in the positive x direction (#1 is positive, so the field lines take off from #1 and #2 is negative, so the field lines approach #2). Therefore the magnitudes of the electric fields of #1 and #2 add and the resultant E is in the positive x direction.
The distance from the point P to the center of #1 (in the origin)= r.
Therefore E_1= \frac{kQ}{r^2}
The distance from the point P to the center of #2 = [L+2R]-r.
Therefore E_2= \frac{kQ}{([L+2R]-r)^2}
And E total= \frac{kQ}{r^2} + \frac{kQ}{([L+2R]-r)^2}
Now substitute this in the integral V= \int_{#2}^{#1} E dl with values of:
E= E total= \frac{kQ}{r^2} + \frac{kQ}{([L+2R]-r)^2}
dl= dr, with dr the projection of dl in radial direction and
#1= R
#2= L+R
(that is the domain of the space between the two spheres where the point P can be chosen in)
This gives:
V= \int_{L+R}^{R} \frac{kQ}{r^2} + \frac{kQ}{([L+2R]-r)^2} dr = \left[ - \frac{kQ}{r} + \frac{kQ}{([L+2R]-r)}\right]_{L+R}^{R} =<br /> ( - \frac{kQ}{R} + \frac{kQ}{(L+R)}) - (-\frac{kQ}{L+R} + \frac{kQ}{(R)}) =
\frac{2kQ}{L+R} - \frac{2kQ}{R}= \frac{2kQR-2kQ(L+R)}{R (L+R)}= \frac{2kQR-2kQL -2kQR)}{R (L+R)}= \frac{-2kQL}{R (L+R)}
Substituting this into the formula of C= \frac{Q}{V} provides:
C= \frac{Q}{ \frac{-2kQL}{R (L+R)}}= \frac{Q R (L+R)}{-2kQ}= \frac{R (L+R)}{-2k}
But given is R<<L, so R= 0 which gives me a C of 0, which can't be possible! So what have I done wrong?!
Is a Taylor Expansion a good possibility?
If so this gives me:
C= \frac{-R}{2k} - \frac{-R^2}{kL}
Is this the right way? & Have I obtained the correct answer? & How do I know if 2 terms of the expansion are enough: do I need to use only 1?
Or maybe I shouldn't let R go to zero? Then again: a negative capacitance is pretty odd...
you found a negative capacitance from your negative Potential Difference.
Your Potential Difference was negative because you integrated
FROM large x-values TO small x-values, instead of along the E-field.
No big deal.
The 2kQ/R was expected ... but the Potential at the +Q was decreased
as the -Q moved in , from infinity far away to only (L+R) away.
The Potential at the -Q sphere went up as +Q came in from infinity to L+R
L >> R means that you can neglect R/L relative to 1 ... L+R = L(1 + R/L) ~ L .
careful with your bookkeeping, I think you lost an L at the end.
dV = 2kQ/R - 2kQ/L => C = R/2k + R^2/2kL
So the Taylor expansion is a good idea?
