Foorier transformation question
  • Thread starter Thread starter electron2
    Transformation
electron2
this is the last part of a bigger question
if you i forgot to mention some data please tell
in the last part i got
\ddot{v_c}+2\dot{v_c}+2v_c=v_s(t)
\dot{v_c(0)}=2
v_c(0)=0
i need to find out if the response for v_s(t)=u(t)+cos(t)
equals the sum of v_c^u(the response for spet function) and v_c^cos the response for cosine
i start by finding the response for cos(t)
v_c(t)->V_c(s)
\dot{v_c}->sV_c(s)-v_c(0)
\ddot{v_c}->s(sV_c(s)-v_c(0))-\dot{v_c(0)}
s(sV_c(s)-v_c(0))-\dot{v_c(0)}+2sV_c(s)-v_c(0)+2V_c(s)=\frac{s}{s^2+1}
<br /> V_c(s)[s^2+2s+2]+2=\frac{s}{s^2+1}<br />
so i get
<br /> V_c(s)=\frac{s}{(s^2+2s+2)(s^2+1)}-\frac{2}{s^2+2s+2}<br />
where \dot{v_c}=j\omega v_c
so now i need to break the fractures into a simpler ones
but here its all complex and i don't know how to get
a simpler fractures and there foorier transformation
so this is where i got stuck
and i even didnt get closer to the main solution of the problem
First of all, unless you put in s = j\omega, the s-domain transformation is known as a Laplace Transform. The Fourier Transform is a special case of the Laplace Transform with s = j\omega.
As for your query, do you know how to express the right hand side in terms of a partial fraction expansion, in terms of functions of s whose inverse Laplace transform (time domain function) is known to you?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
