Force acting on the area of the cylinder due to gas
The discussion revolves around calculating the force acting on a cylinder due to gas using the ideal gas law. The initial attempt incorrectly focused on pressure rather than force, leading to confusion about the correct formula. It was clarified that to find force, one must multiply pressure by the area of the cylinder. Additionally, the distinction between the number of moles (n) and the number of molecules (N) is crucial, as the problem specifies the latter. The relationship between the Boltzmann constant and the ideal gas law was also highlighted, ultimately leading to a successful resolution of the problem.
youmei0426
pV=nRT
I know the volume of the cylinder, which is Al. So I plugged this into the ideal gas law formula, and got answer B. However, the correct answer should be D. I see the Boltzmann's constant there in the equation, and I do know an equation which contains the constant, but I'm not sure how to incorporate it into the ideal gas law.. Thanks for your help in advance!
Can you somehow relate ##P## with the kinetic energy of the gas molecules per unit volume ##E_{\text{unit vol.}}##?
First, you need a Force, not a pressure. What you did, I think, was $$p = nRT/V = \frac {nRT} {A l}$$ but this is a pressure. You have to multiply by the area, so $$F = \frac {nRT} {l}$$.
Second: in the perfect gas law you have ##n## which is the number of moles, but the exercise gives you ##N## which is number of molecules! And Remember that ##k_B = \frac R N_a## where ##N_a## is the Avogadro constant
Thank you so much! I figured it out :)
