Force and Potential energy funtion
The discussion centers on the Yukawa potential, which accurately describes the interaction between nucleons, specifically neutrons and protons, with constants r0 = 1.5x10-15 meters and U0 = 50 MeV. The force of attraction is derived using the formula Fr = -dU/dr. Despite initial confusion regarding the sign of the force, it is clarified that while the force points in the direction of attraction (negative), its magnitude is expressed as a positive value, confirming the nature of the attractive force.
  • Understanding of Yukawa potential in nuclear physics
  • Familiarity with the concept of force as the negative gradient of potential energy
  • Basic knowledge of calculus, specifically differentiation and integration
  • Awareness of the properties of attractive forces in physics
  • Study the derivation of the Yukawa potential and its applications in nuclear physics
  • Learn about the mathematical principles behind force calculations in potential energy contexts
  • Explore the implications of attractive forces in particle physics
  • Investigate other potential energy functions and their corresponding force equations
Students and professionals in physics, particularly those focusing on nuclear interactions, as well as educators seeking to explain the concepts of force and potential energy in a clear and structured manner.
Sabreen Khan
1. The so-called Yukawa potential
(attached)
gives a fairly accurate description of the interaction between nucleons[that is, neutrons and protons, the constituents of the nucleus]. The constants r0 = 1.5x10-15metres and U0 = 50 MeV.[a] Find the corresponding expression for the force of attraction.
2. Fr= -dU/dr
3. When i finnaly calculate it, the answer is supposed to be negative because
Fr= - dU/dr
= - d (U is given negative)/dr
{ -ve and -ve cancels out }
Fr= +ve d(U)/dr
after integrating U, a -ve sign appears...
so...shouldnt the answer be negative? but the actual solution is a positive. can u tell me y ?
When you find the force by via -dU/dr, the resulting sign will tell you which way the force points (with respect to the variable r). Since it's an attractive force, that will be negative. The magnitude of the force of attraction will be positive, of course.
thanks for the reply
  • · Replies 23 ·
  • · Replies 22 ·
