Force and Pulley Problem (Pic Included)
The discussion focuses on calculating the tensions in a pulley system with a mass M, where the pulleys are massless and frictionless. The user initially deduces that FT1 equals mg/2 due to the force being split, and calculates FT4 as 3mg/2 based on the sum of tensions. However, a more accurate method is suggested, emphasizing the analysis of forces on the pulleys rather than simply halving the force. The correct relationships are established through equilibrium considerations, leading to the conclusion that FT2 and FT3 are equal, and the tensions can be derived systematically. Overall, the user confirms their answers are correct but appreciates the clarification on the proper approach to solving pulley problems.
Dcarroll
A mass M is held in place by an applied force , FA , and the pulley system shown in the figure below. The pulleys are massless and frictionless. Express the tension in each section of the rope, FT1, FT2, FT3, FT4, and FT5, as well as the applied force, FA , in terms of M and g.
Here is a picture I found online:
F=ma
I looked at the picture and saw that the force being applied by mass M was split in half because of the strings separating. I then came to conclusion that FT1 must be FT1=mg/2, because the force of mass M was cut in half(I think this is correct).
I then looked at FT4 and knew that it was the addition of FT1+FT5. The masses force was split in half like i said earlier, so now FT2+FT3+FT1=FT4. mg/2+mg/2+mg/2= 3mg/2. So the force on FT4 is 3mg/2 (I think this is the correct answer).
FT5 is just the force of mass M pulling down, so FT5=mg
To wrap it all up these are my answers:
FT1=mg/2
FT2=mg/2
FT3=mg/2
FT4=3mg/2
FT5=mg
FA=FT1=mg/2
I just want to see if my thought process is right on these and if my answers are correct. We have not gotten into pulleys yet so it was somewhat of an educated guess.
Hi Dcarroll! :smile:
FT1=mg/2
FT2=mg/2
FT3=mg/2
FT4=3mg/2
FT5=mg
FA=FT1=mg/2
Yes, they're all correct. :smile:
But I don't like your "cut in half" argument …
the correct method is to say "consider the forces on the small (masless) pulley" … they are T2 + T3 up, and T5 down; and T2 = T3, and the acceleration is zero, so 2T3 - T5 = 0
similarly, consider the forces on the large pulley, and the forces on the mass M :wink:
Ahh ok thanks a bunch, like i said if never done pulleys so the correct way to do things helps lol
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
