Force between the plates of a plane capacitor
The discussion focuses on deriving the force between the plates of a plane capacitor, showing that the plates attract each other with a force of F=q^2/(2ε0A). The energy stored in the capacitor is expressed as U=(1/2)ε0E^2Ax, where the electric field E is rewritten in terms of charge q and area A. The work done to separate the plates is calculated, leading to the expression for force as F=(1/2)(q^2)/(ε0A). A participant points out an error in the substitution regarding the area A, which is acknowledged and corrected. The thread emphasizes the importance of rigorous mathematical derivation in physics problems.
pc2-brazil
I found this problem while self-studying Electricity and Magnetism, and I want to know if my solution is rigorous.
Show that the plates of a plane capacitor attract each other mutually with a force equal to
F=\frac{q^2}{2\epsilon_0 A}
Obtain this result by calculating the work required to increase the separation between the plates from x to x + dx.
Energy stored in a capacitor with electric field E, plate area A and distance x between the plates:
U=\frac{1}{2}\epsilon_0 E^2 Ax
The energy U stored in a capacitor can be viewed as the work that needs to be done by an external agent to separate its plates by a distance x:
The electric field E can be rewritten as q/(\epsilon_0 A), where q is the magnitude of the charge on each plate. Thus, the work can be rewritten as:
U=\frac{1}{2}\frac{q^2 x}{\epsilon_0 A}
The work dU done by the external agent to separate the plates from a separation x to a separation x + dx is:
dU=\vec{F}\cdot d\vec{x}
where \vec{F} is the force applied by the external agent.
Because in this situation force and displacement are in the same direction, it may be rewritten as:
dU=Fdx
Isolating the force:
F=\frac{dU}{dx}
Thus:
F=\frac{d}{dx}\frac{1}{2}\frac{q^2 x}{\epsilon_0 A}
F=\frac{1}{2}\frac{q^2}{\epsilon_0 A}
Thank you in advance.
Likes gracy
Looks like an error substituting in the q/(ϵ0A). Shouldn't you end up with an A on the bottom instead of on the top?
Yes, there was an error; I've just corrected it.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
