Force Calculation: Help with Question 8
  • Thread starter Thread starter jjg242
To calculate the force exerted on the board by the karate master, the relevant equations are momentum and impulse, represented as mv = Ft. The change in velocity is determined by subtracting the final velocity (1 m/s) from the initial velocity (10 m/s), resulting in a change of 9 m/s. Using the mass of the hand and arm (1 kg) and the contact time (0.002 s), the force can be calculated as F = (mass * change in velocity) / time, leading to a force of 4500 N. The discussion confirms this calculation is correct, and additional resources for understanding impulse and momentum are provided.
jjg242
8. A karate master strikes a board with an initial velocity of 10 m/s, decreasing to 1 m/s as his hand passes through the board. If the time of contact with the board is 0.002 s, and the mass of the coordinated hand and arm is 1 kg, what is the force exerted on the board.
a. 1000 N
b. 1800 N
c. 2700 N
d. 4500 N
- well, I lost my book because my backpack got stolen and I have an older physics book i got from a friend and the pages don't match up with my study guide. I can't find the right equation for this. I need an equation that uses change in velocity, contact time, and mass of the object to get F in Newtons. If anyone can show me how I do this or at least point me in the right direction I would appreciate it.
Momentum=Impulse
mv=Ft
laminar said:
Momentum=Impulse
mv=Ft
so...
m = mass
v= change in velocity?
F= force in N
t= time
is v the initial, final, or change in velocity?
if it is change in velocity, then i get:
9*1/0.002 = 4500 N
Is this right?
bump. any feedback appreciated.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
