What is the effect of distance on the force created by a laser in outer space?
  • Thread starter Thread starter bmb2009
    Em Force Laser
bmb2009
Two astronauts are at rest in outer space, one 15.3 m from the Space Shuttle and the other 30.6 m from the Shuttle. Using a 123.0-W laser, the astronaut located 30.6 m away from the Shuttle decides to propel the other astronaut toward the Space Shuttle. He focuses the laser on a piece of totally reflecting fabric on her space suit. If her total mass with equipment is 129.0 kg, how long will it take her to reach the Space Shuttle?
Force=Power/c
Since Force=Power/speed of light
F=(123W)/(3x10^8)
F=4.1E-7 since F=ma (4.1E-7)/129kg = accel= 3.178E-9 m/s^2
the laser causes constant acceleration so...
Df=Do + VoT+ 1/2aT^2
and I solved for T... with Df = 15.3 meters, Do and Vo both equal 0.
but this didn't work and I have no idea where to go from here. Does the distance of the second astronaut (the one shooting the laser) affect the calculation? Any help?
Thanks!
This is just a suggestion:
If it's a totaly reflecting surface shouldn't the force (F) of the beam be doubled?
Just like if water hits the back of a spoon as compared to the front of a spoon. The water hitting the front is deflected and therefore puts a greater force on the spoon.
I just tried your hunch and you were correct. Thanks a bunch!
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
