Force, Electric Field, and Positive Particle
The discussion focuses on calculating the location where an alpha particle experiences no net force due to a charged line and a charged sheet. The relevant equations for the electric fields generated by the line and the sheet are presented, and an attempt to solve for the distance from the line where the forces balance is made. The solution indicates that the calculated distance of approximately 0.1592 m is above the line, as the electric field vectors act in opposite directions to the force on the positive alpha particle. The participant expresses uncertainty about the setup and the use of formulas. Overall, the discussion revolves around the application of electric field equations to find equilibrium points for charged particles.
Soaring Crane
A long line carrying a uniform linear charge density 50.0 microcoulombs/m runs parallel to and 10.0 cm from the surface of a large, flat plastic sheet that has a uniform surface charge density of -100 microcoulombs/m^2 on one side.
Find the location of all points where an alpha particle would feel no force due to this arrangement of charged objects.
Indicate this location as a distance from the line.
Choose an appropriate location of these points at a distance: above the line or between the line and the sheet.
E = [1/(2*episilon_0*pi)]*(lambda/r) for wire
E = omega/(2*episilon_0) for sheet (Do I use this formula?)
I don’t know if I set this up correctly or used the correct formulas.
E = [1/(2*episilon_0*pi)]*(lambda/r) + omega/(2*episilon_0)
0 = [1/(2*episilon_0*pi)]*(lambda/r) + omega/(2*episilon_0)
-omega/(2*episilon_0) = [1/(2*episilon_0*pi)]*(lambda/r)
r = (lambda)/(-omega*pi) = (50*10^-6 C/m)/[pi -(-100*10^-6 C/m^2)] = 0.1592 m ?
This distance would be above the line because the electric field vectors, which are in same direction as force vectors, on the positive alpha particle would be in opposite directions??
Thanks.
It looks fine to me. Is something unclear?
