Force Equations and Final Speed
A 7.0-kg rock is subjected to a variable force described by the equation F(x) = 6.0N - (2.0N/m)x + (6.0N/m^2)x^2, and the task is to determine its speed after moving 9.0m from rest. Initial calculations using the kinematic equation for constant acceleration yielded an unreasonably high final speed of 1219 m/s. It was noted that the assumption of constant acceleration was incorrect due to the variable nature of the force. By calculating the work done on the rock through integration, the correct work value of 1431J was found, leading to a final speed of 20.22 m/s. The discussion highlighted the importance of applying work-energy principles for problems involving variable forces.
odie5533
A 7.0-kg rock is subject to a variable force given by the equation
If the rock initially is at rest at the origin, find its speed when it has moved 9.0m.
\sum F_{x} = 6 - 2x + 6x^2
ma=6 - 2x + 6x^2
a = \frac{6}{7} - \frac{2}{7}x + \frac{6}{7}x^2
V_{f}^2 = V_{i}^2 + 2*a*x
V_{f}^2 = 0 + 2(\frac{6}{7} - \frac{2}{7}x + \frac{6}{7}x^2)x
V_{f}^2 = 2(\frac{6}{7} - \frac{2}{7}(9) + \frac{6}{7}(9)^2)(9)
V_{f} = 1219m/s
That seems waaay too fast, and I think I should have used an integral/derivative somewhere since the force changes as x changes. I'm rather lost on this one.
This kinematic equation assumes constant acceleration--not a good assumption for this problem.
Hint: How much work is done on the rock?
I think I have it now.
W = \int^{9}_{0} 6 - 2x + 6x^2 dx = 1431J
W = \frac{1}{2}mv_{f}^2 - \frac{1}{2}mv_{0}^2
1431 = \frac{1}{2}7v_{f}^2
v_{f} = 20.22m/s
Any improvement?
Looks good to me!
Thanks for the help. I've never done a problem like that, all the ones I've completed so far have used the kinematics equations. I guess I'll have to learn how to apply the work equations better.
