Force magnitude from acceleration vs. mass graph?
To find the magnitude of a force from an acceleration vs. mass graph, it's important to understand that the relationship is defined by Newton's Second Law, F=ma. The graph typically shows how different masses respond to the same force, resulting in varying accelerations. Replotting the data as acceleration vs. 1/mass can help clarify the relationship. This allows for the determination of the force by analyzing the slope of the new graph. Understanding this concept is crucial for solving related physics problems effectively.
lawsonj
I am a new university physics student doing some homework, but i cannot find the method for this problem.
How do I find the magnitude of a force from an acceleration vs. mass graph?
I know mass is the inverse of the slope of an acceleration vs. force graph, but I'm not sure how to do this the other way around.
Any help?
Thank you !
Any help?
Thank you !
Your question makes no sense. If you are plotting acceleration vs. mass, you must be plotting the response of numerous different objects (having different masses) and being subject to some forces, leading to some accelerations, possibly different for each of the different objects.
I would replot acceleration vs 1/mass.
yes. it may be multiple objects, but there is only 1 force acting on them. I'm assigned to find the magnitude of that force.
"The following figure shows the acceleration of objects of different mass that experience the same force."
"What is the magnitude of the force? "
how would that let me find the magnitude of the force?
We just started this chapter and I guess the book assumes you know how to find the magnitude from the graph. I don't know how to do that.
Use Newton's Second Law.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
