How Do I Calculate the Force of a Punch in Ft/lbs?
  • Thread starter Thread starter jaywoo
    Force
To calculate the force of a punch, the user has data from an accelerometer and a high-speed camera, along with the mass of the moving fist. The formula for force is F = mass × acceleration, where acceleration can be derived from the accelerometer readings. Energy can be calculated using the formula energy = force × distance, and impulse is defined as force × time. The user is also seeking specifications for a 40g accelerometer to ensure it won't break during use. Resources like prosporttech.com are recommended for further information on training equipment.
jaywoo
I need to calculate the force of a punch for a test I'm running. I have the numbers, but it seems that I have to backwards to find my number!.
I have the force of a punch in G's given by a sensor (accelerometer)
I have Ft/s (feet per second) (high speed Camera) will have anyway by thisafternoon.
I have the mass (6lb moving "fist" on a pnumatic cylinder)
I need Ft/lbs of the punch.
Can anyone give me my formula?
Many Many thanks indeed!
Ft/lbs doesn't mean anything.
If you mean the force than F = mass 8 acceleration , you have that from the acceleromter. 1g = 9.8m/s^2 or 32ft/s^2.
Energy is force * distance, ft*lbs. Or you could get it from the kinetic energy of the fist.
Impulse is force*time.
what was the Accelerometer data?
Im looking to get an Accelerometer (40g) and i want to know the spec's i need so that it won't break.
thanks in advance
Hi
go to www.prosporttech.com[/URL] we use Herman Digital Trainers for martial Arts, American Football, Rugby and most other contact sports.
Check it out, it should give you every thing you need.
Andy
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
