What is the force of gravity at different distances from the center of Earth?
The discussion focuses on calculating the force of gravity at different distances from the Earth's center, starting with a known force of 750N. The equation F=mg is initially mentioned, but it is clarified that the correct approach is to use F=G*m1*m2/distance^2. The gravitational constant G is noted, but it's pointed out that it is not necessary for this specific problem since the mass of the Earth is not provided. The conversation emphasizes understanding the relationship between gravitational force and distance, highlighting that as distance increases, the force decreases according to the inverse square law. Overall, the key takeaway is the importance of using the correct gravitational formula for varying distances.
soulja101
The force of gravity experienced by a person on Earth is 750N. What is the force of gravity on the same person aat each of the following distances, in multiples of the Earth's radius from the centre of earth?
FG=mg
The answers are A)3 B)10 C)22
750N/9.8N/kg
=76.53
If you want to find the force of gravity at different distances use the equation-
F=G* mass1*mass2/distance^2
G=gravitational constant or 6.67*10^-11
masses in kilograms
distance in meters
the final force in Newtons
hover:
The universal gravitational constant is not needed to answer this question. (Besides, you didn't give the mass of the Earth.)
Soulja:
Using F=mg is not correct; hover's equation is correct.
You know the force at one Earth radius. Using F = \frac{G m_1 m_2}{r^2}, can you determine the relation between the forces if the masses remain constant but the distance is varied?
sorry, my bad:blushing:
Nothing to apologize about. You provided the governing equation.
