Force of Water in 8" Steam Pipe w/ 90° Bend
  • Thread starter Thread starter meggs521
    Force Pipe Water
The discussion centers on calculating the force exerted by steam and condensate in an 8" steam pipe with a 90-degree bend. The scenario involves steam at 80 psia and a 10-foot plug of condensate, with velocities of 4000, 6000, and 10000 feet per minute to consider. The intern seeks guidance on the appropriate equations to use, noting the mass of the water in the pipe. Alternatives to the 90-degree bend, including a 45-degree slant and a blind flange, are also mentioned, with questions about whether the same methods apply. The inquiry highlights a need for clarity on fluid dynamics and force calculations in engineering contexts.
meggs521
Hey guys, I've been reading threads on here for a little bit and now I have a question I need some help with. I tried doing a search, but I didn't really know what I was looking for so it wasn't too successful. But here it is:
My boss gave me this question to figure out and I'm not really sure where to start. I'm interning with an engineering firm and the following question arose.
If we have an 8" Steam pipe that has steam at 80 psia and some of the steam condenses within the pipe forming a "plug of condensate" about 10' long, how much force will be applied on the end of the pipe if it goes into a 90 degree turn with a short radius?
The velocities I'm supposed to check this for are 4000 fpm, 6000 fpm, and 10000 fpm. I'm currently a sophomore in engineering, so I don't know too much about how to do this. Of course F=ma and all that, but without the acceleration I'm kind of lost.
I also know that in an 8" pipe the mass of water is approximately 21 lbs/ ft, so at 10' there's roughly 210 lbs of water. What sort of equation or method should I be using?
Any help would be very helpful as I'm pretty lost. Here's a picture of the pipe in case my description wasn't good enough.
Thanks again!
~Meg
I also have two alternatives to the 90 degree bend. One is a 45 degree slant and the other simply has the pipe end with a blind flange. I've attached pictures of each of these as well.
Would I solve these two the same way as the above problem?
Answered your question in the engineering forum
Thanks! I reposted it here because I thought it might be more of a general physics problem.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
