Force on a dipole from a point charge?
The discussion centers on calculating the force acting on a dipole placed in the electric field of a point charge located at the origin. The electric field of the point charge is given by E = (1/4πε₀)(q/r²), and the force on the dipole is derived from the gradient of this electric field. The gradient of the electric field is calculated as ∇E = (-q/2πε₀r³)â_r, leading to a force expression that includes the dipole's radial component. The dipole will align with the electric field, resulting in a torque that depends on the angle between the dipole moment and the radial vector. Ultimately, this alignment creates a slight attractive force, influenced by the dipole's orientation relative to the point charge.
warfreak131
A point charge q is situated at the origin. A dipole p is placed at r. The angle θ is defined by \hat{p}\cdot\hat{r}=cos(\theta)
Calculate the vector force Fp acting on the dipole by the nonuniform E field of the point charge.
I know that the E field of a point charge is 1/4pi e0 * q/r2, and that F=(p\cdot\nabla)E=\nabla E\cdot p
So since the E field of the point charge doesn't rely on phi or theta, i can just say that \nabla E=\frac{dE}{dr}\hat{r}=\frac{-q}{2\pi\epsilon_{0}r^{3}}\hat{r}
Now if I dot that result with p, only the radial portions will remain since E_{\theta}=E_{\phi}=0
All that remains is \frac{-qp_{r}}{2\pi\epsilon_{0}r^{3}}
Won't the dipole tend to do react to charge q in the following ways. It will align with the electric field of the charge q ( let q be positive for this example) such that the negative end of the dipole is closest to q, there is a torque on the dipole which depends on the angle between the vectors r and p.
Once the dipole aligns the negative end of the dipole is slightly closer to the positive charge then the positive end of the dipole so this will result in a slight attractive force.
Part of your answer should have a theta dependance?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
