Force on an Incline Plane Problem HELP
A 63-kg skier on a 30° incline with a friction coefficient of 0.20 is trying to calculate acceleration. The initial calculation yielded -102.14, but the correct approach involves using the equation mAnet = mgsin(30) - μFn, where Fn is derived from Fn = mgcos(30). The skier mistakenly thought to input the absolute value, leading to confusion when the answer was marked incorrect. Clarification was provided that mass cancels out in the equation, simplifying the calculation. The skier was guided to correctly substitute values to find the proper acceleration.
whoopie88
A 63-kg person on skis is going down a hill sloped at 30° from the horizontal. The coefficient of friction between the skis and the snow is 0.20. What would be the magnitude of the acceleration?
f=ma
fg=mg
fnet=mAnet
Ff=μῦFn
I got -102.14, but I'm supposed to put it in as 102.14 right? Because the magnitude is the absolute value of whatever I get..? I found Fnet by subtracting Ff from Fg,x. I got 535.23 for Fn.
PLEASE HELP!? I put in 102.14 on the Webassign but it came back as wrong.
Thank you all!
Show your calculations.
Fn = Fg,y
Fn = mgcos30
Fn = 63(9.81)cos30
Fn = 535.23
Fnet = mgsin30 - μῦFn
mAnet = mgsin30 - μῦFn
Anet = gsin30 - μῦFn
Anet = 9.81sin30 - 0.2(535.23)
Anet = -102.14
And as I mentioned earlier, I changed it to positive 102.14.
Thanks for your time.
The above equation should be
m*Anet = m*g*sin(30) - μ*m*g*cos(30)
Now solve for A.
Thank you for your help, I didn't realize m canceled out for the Fn formula until you showed me how I could use substitution. Thank you!
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
