Calculating Force on an Oscillating Mass: A Simple Harmonic Motion Problem
A 2.10 kg mass attached to a spring with a force constant of 6.00 N/m is displaced 3.09 m and released, initiating simple harmonic motion. The angular frequency is calculated as 1.69 rad/s, and the displacement function is x(t) = 3.09 cos(1.69t). After 4.18 seconds, the correct displacement is found to be approximately 2.195 m, leading to a force calculation using Hooke's Law. The initial confusion stemmed from misreading the displacement and using degrees instead of radians in calculations. The thread concludes with the user successfully solving the problem after clarifications from others.
jumpingjack90
Force on an oscillating mass?
A 2.10 kg mass on a frictionless horizontal track is attached to the end of a horizontal spring whose force constant is 6.00 N/m. The mass is displaced 3.09 m to the right from its equilibrium position and then released, which initiates simple harmonic motion. What is the force (including direction, choose the right to be positive) acting on the mass 4.18 s after it is released?
F=kx
w=(sqrt)k/m
x(t)=xm*cos(w*t+phase costant)
Find angular frequency
w=(sqrt)k/m=(sqrt)6.00/2.10=1.69rad/s
2-The displacement is given as a function of time:
the function is:
x(t)=3.09*cos(1.69t)
the hooke law for spring is:
F=-kx
x(4.18)=3.09*cos(1.69*4.18)=3.06m
the force acting is:
F=-6.00*3.06=18.36N
Which is the incorrect answer. I'm not sure what I'm doing wrong. any help will be greatly appreciated. thanks!
Did you forget the negative sign in front of 18.36 N ?
Whoops, ignore whatever I wrote earlier, if you caught it, I misread your answer.
Everything looks peachy from here, negative sign aside.
For a simple harmonic oscillator:
x(t)=A\cos{(\omega t + \theta)}
Your initial conditions dictate that this be a cosine function with a phase constant 0 (Since its at its max amplitude at t=0)
x(t)=3.09\cos{(1.69t)}
Haha! I feel so dumb. I was operating under degrees instead of radians in my calculator. I suspect the thread-starter made the same mistake.
You're on the right track, but 3.09\cos{(1.69*4.18)} is approximately 2.195, and not 3.06.
An additional issue is that
3.09*cos(1.69*4.18) does not give 3.06. You need to redo the calculation.
solved it! thanks for the input everyone!
