Force on Ice Skater's Hand: Calculate & Express as a Multiple of Hand Weight
A 54.0 kg ice skater spins at 2.50 turns per second with her arms outstretched, leading to a calculated horizontal force of 125 N exerted on her hand. Each hand weighs approximately 0.675 kg, making it 1.25% of her body weight. To express the force as a multiple of her hand's weight, the user was advised to divide the force by the weight of the hand, resulting in a dimensionless number. The user found this explanation helpful and appreciated the quick responses available in the forum compared to waiting for professor feedback. Overall, the discussion highlights the importance of understanding force calculations in rotational motion.
Abarak
Question
A 54.0kg ice skater spins about a vertical axis through her body with her arms horizontally outstretched, making 2.50 turns each second. The distance from one hand to the other is 1.5m. Biometric measurements indicate that each hand typically makes up about 1.25% of body weight.
Hand breakdown:
m = .675kg
r = .75m
\omega = 2.50\frac{rev}{s} = 15.707\frac{rad}{s}
F = 125N
Part A:
What horizontal force must her wrist exert on her hand?
I figured this one out by using F=m*r*\omega^2
Part B:
Express the force in part (a) as a multiple of the weight of her hand.
My Problem:
I am getting confused with "as a multiple". Pardon my lack of knowledge but I have no idea what they are asking for? I know the answer box is looking for a unit of weight (w).
Sorry about the "easy" question and thank you for taking time in reading my post.
-- Abarak
I think you just want to divide the force on the hand by mg. Which would be the weight on the hand. A multiple of weight would not be a weight, but a dimensionless number.
Hey Dick,
Thanks for the help. I was able to get the correct answer.
Man, I could never do what you Homework Helper's do but it REALLY helps!
I am taking an online physics class right now and not having someone to talk to really sucks. If I need to ask my professor a question it takes days to get a response while I can get one here within hours or minutes.
-- Abarak
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
