Force on object at angle to acceleration
To determine the force Joe must apply to the lawn spreader, first calculate the required acceleration using the final velocity of 1.35 m/s and the time of 1.3 seconds. Once the acceleration is established, analyze the forces acting on the spreader, ensuring the net force aligns with the direction of acceleration. The fundamental equation to apply is F=ma, where F is the net force, m is the mass of the spreader (10.5 kg), and a is the calculated acceleration. The angle of the handle (42°) may also affect the force component calculations. Completing these steps will yield the necessary force in Newtons.
djtsmith007
Joe pushes down the length of the handle of a
10.5 kg lawn spreader. The handle makes an
angle of 42◦ with the horizontal. Joe wishes to
accelerate the spreader from rest to 1.35 m/s
in 1.3 s.
What force must Joe apply to the handle?
Answer in units of N.
I can't even figure out which equation to use :(
Can you figure out what the acceleration should be based on what is given?
If you can, then you can analzye all the Forces on the spreader and make sure that the net force is in the same direction as the acceleration. Then it just comes down to F=ma
I can find acceleration, but not sure how else to finish it
anyone
