What are the sign conventions for force in physical chemistry?
  • Thread starter Thread starter hackerdiety03
    Force Sign
In physical chemistry, sign conventions for force are crucial for understanding dynamics. Tension is considered positive, while compression is negative, with force in the direction of motion being positive and opposite force negative. According to the equation F = m * a, positive force results in positive acceleration, while negative force leads to deceleration. For pressure, force directed towards the surface normal is positive, and force against it is negative. Overall, the positive and negative signs reflect the direction of the applied force, emphasizing that force and acceleration are vector quantities with both magnitude and direction.
hackerdiety03
hey there! i am taking a physical chemistry course at my college. an assignment given was about miniature machines: "pulling" nanowires. one of the questions asked is concerning the types of sign conventions of force. i have tried to research this topic had have trouble finding out the different sign conventions. help!
Tension is considered positive, compression negative.
Force in the direction of motion is positive, force opposite direction of motion is considered negative.
Think of F = m \ddot{x}
Positive F should yield positive acceleration, negative force yields deceleration.
With respect to pressure (force per unit area), force in direction of surface normal would be positive, force opposite direction of normal would be negative.
so these are considered the sign conventions of force? the positive/negative signs depending on the direction of the force of the object and other conditions?
Basically, yes.
Force and acceleration are vector quantities - and being so, they have magnitude and direction. The magnitude is always positive. The use of (+) and (-) relates to the direction in which the force is applied.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
