Show equivalence of Force to Lorentz Force
In summary, the force given by the equation \dot{P}=e(\vec{∇}\vec{A})\vec{\dot{x}}-e\vec{∇}\phi is equivalent to the Lorentz force, as shown through the derivation from the principle of least action and the Euler-Lagrange equations. The notation used on Wikipedia can be confusing, but using the Ricci calculus clarifies the steps and shows the vector identity involved.
vinceclortho
Greetings,
I am trying to to show that the force in this form:
[itex]\dot{P}=e(\vec{∇}\vec{A})\vec{\dot{x}}-e\vec{∇}\phi[/itex]
Is equal to the lorentz force. I have been trying the approach of some sort of vector identity but have not gotten anywhere.
The equation and where I am trying to get with it are posted on wikipedia towards the bottom:
http://en.wikipedia.org/wiki/Hamiltonian_mechanics
I appreciate any help!
The equation of motion is given by (in Heaviside-Lorentz units)
[tex]m \frac{\mathrm{d}}{\mathrm{d} t} \left (\frac{\dot{\vec{x}}}{\sqrt{1-\dot{\vec{x}}/c^2}} \right)=q \left (\vec{E}+ \frac{\vec{v}}{c} \times \vec{B} \right )=q \left [-\vec{\nabla} \phi + \frac{\vec{v}}{c} \times (\vec{\nabla} \times \vec{A}) \right ].[/tex]
To derive it from the principle of least action, I prefer the Lagrangian form, because there the action is manifestly covariant:
[tex]L=-mc^2 \sqrt{1-\vec{v}^2/c^2}-q \left (\phi-\frac{\dot{\vec{x}}}{c} \cdot \vec{A} \right ).[/tex]
The action is manifestly covariant, because
[tex]\sqrt{1-v^2/c^2} \mathrm{d} t = \mathrm{d} \tau = \sqrt{\mathrm{d} x_{\mu} \mathrm{d} x^{\mu}}[/tex]
and
[tex](\phi-\frac{\dot{\vec{x}}}{c} \cdot \vec{A}) \mathrm{d} t = \mathrm{d} t \frac{1}{c} \frac{\mathrm{d} x^{\mu}}{\mathrm{d} t} A_{\mu}=\frac{1}{c} \mathrm{d} x^{\mu} A_{\mu}.[/tex]
The four potential [itex](A^{\mu})=(\phi,\vec{A})[/itex] is a Mikowski four-vector.
To get the equations of motion, you just write down the Euler-Lagrange equations
[tex]\frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial L}{\partial \dot{\vec{x}}}=\frac{\partial L}{\partial \vec{x}}.[/tex]
Just taking the derivatives, gives
[tex]\vec{P}=\frac{\partial L}{\partial \dot{\vec{x}}}=\frac{m \dot{\vec{x}}}{\sqrt{1-\dot{\vec{x}}^2/c^2}}+\frac{q}{c} \vec{A}.[/tex]
Here it is important to note that [itex]\vec{P}[/itex] is the canonical momentum, not the mechanical momentum, which is given by the first term only.
Further we have
[tex]\frac{\partial L}{\partial \vec{x}}=-q \vec{\nabla} \phi + \frac{q}{c} \vec{\nabla} (\dot{\vec{x}} \cdot \vec{A}).[/tex]
Written in the three-dimensional Ricci calculus (with all indices as subscripts) the equation of motion thus reads
[tex]\dot{P}_j=\frac{\mathrm{d}}{\mathrm{d} t} \left (\frac{m \dot{x}_j}{\sqrt{1-\dot{\vec{x}}^2/c^2}} + q A_j \right ) = \frac{\mathrm{d}}{\mathrm{d} t} \left (\frac{m \dot{x}_j}{\sqrt{1-\dot{\vec{x}}^2/c^2}} \right ) + \frac{q}{c}\dot{x}_k \partial_k A_j = -q \partial_j \phi + \frac{q}{c} \dot{x}_k \partial_j A_k.[/tex]
Combining the two terms with the vector potential on the right-hand side gives
[tex]\frac{\mathrm{d}}{\mathrm{d} t} \left (\frac{m \dot{x}_j}{\sqrt{1-\dot{\vec{x}}^2/c^2}} \right )=-q \partial_j \phi + \frac{q}{c} \dot{x}_k (\partial_j A_k-\partial_k A_j).[/tex]
The last term can be rewritten as
[tex]\dot{x}_k (\partial_j A_k-\partial_k A_j) =\dot{x}_k \epsilon_{jkl} (\vec{\nabla} \times \vec{A})_l=[\dot{\vec{x}} \times (\vec{\nabla} \times \vec{A})]_j.[/tex]
Rewriting everything in vector notation yields the correct equation of motion.
Note that the notation in Wikipedia, from where you copied your equation, is not very clear. That's why I used the Ricci calculus in the intermediate steps, where it is clear what are free indices and which are repeated indices to be summed.
[tex]{\bf F}=-e\nabla\phi-e\partial_t{\bf A}+e{\bf v\times(\nabla\times A)}[/tex]
[tex]=-e\nabla\phi-e\partial_t{\bf A}+e\nabla{\bf(v\cdot A)}-e{\bf(v\cdot\nabla)A}[/tex]
[tex]=-e\nabla\phi+e\nabla{\bf(v\cdot A)}-e\frac{\bf dA}{dt}.[/tex]
1. What is the concept of force equivalence in physics?
The concept of force equivalence in physics states that there are different types of forces that can produce the same effect on an object. This means that two or more forces can be considered equivalent if they result in the same acceleration or motion of an object.
2. How is force equivalence related to Lorentz force?
In the context of electromagnetism, the Lorentz force is the combination of electric and magnetic forces acting on a charged particle. This force is equivalent to the force exerted on the same charged particle by an electric field and a magnetic field separately.
3. What is the mathematical equation for Lorentz force?
The mathematical equation for Lorentz force is F = q(E + v x B), where F is the Lorentz force, q is the charge of the particle, E is the electric field, v is the velocity of the particle, and B is the magnetic field.
4. How can we show the equivalence of force to Lorentz force?
The equivalence of force to Lorentz force can be shown by comparing the mathematical equations for both forces. By substituting the values for electric and magnetic fields in the Lorentz force equation, it can be seen that it is equivalent to the force equation for a charged particle in an electric field and a magnetic field separately.
5. What are some practical applications of force equivalence and Lorentz force in science and technology?
Force equivalence and Lorentz force have many practical applications in various fields such as particle accelerators, magnetic resonance imaging (MRI), and electromagnetic propulsion systems. These concepts are also crucial in understanding the behavior of charged particles in electric and magnetic fields, which is essential in many areas of physics and engineering.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
