How Is Engine Power Related to Velocity and Resistive Force in Automobiles?
The discussion revolves around calculating the resistive force and required engine power for an automobile at different speeds. The resistive force at 78 km/h is determined to be 1376.465 N. For speeds of 65 km/h and 145 km/h, the engine power required is questioned, with the assumption that resistive force is proportional to velocity. The relationship is established as F proportional to v, leading to the conclusion that power can be expressed as P = kv². To solve for the engine power at different speeds, the constant k must first be determined.
mjdiaz89
The engine of an automobile requires 40 hp to maintain a constant speed of 78 km/h.
(a) What is the resistive force against the automobile?
correct check mark
1376.465N (correct)
(b) If the resistive force is proportional to the velocity, what must the engine power be to drive at constant speeds of 65 km/h?
wrong check mark
hp
(c) What must the engine power be to drive at constant speeds of 145 km/h under the same conditions?
wrong check mark
hp
P=Fv = \frac{Fd}{s}
Questions B and C: It seems I have two unknowns (Resistive force and engine power output). Any ideas?
Since you are assuming that resistive force is directly proportional to velocity, you know:
F \propto v
F = kv
Therefore:
P = Fv
P = kv^{2}
You now need to find the constant k, then you'll be all set.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
