What is the acceleration of a sled in a tractor-pull competition?
  • Thread starter Thread starter Enduro
    Forces
In a tractor-pull competition, a tractor exerts a force of 1.3 kN on a sled weighing 11,000 kg, with a kinetic friction coefficient of 0.80. The frictional force is calculated to be 86,240 N, which opposes the tractor's force. Using Newton's second law, the net force acting on the sled is determined, leading to an acceleration of approximately 7.85 m/s². The discussion highlights the importance of considering both the applied force and friction when calculating acceleration. Understanding the sign of acceleration is crucial, as it indicates the sled's direction of movement relative to the forces acting on it.
Enduro
applies a force of 1.3 kN to the sled, which
has mass 1.1 × 104 kg. At that point, the coefficient
of kinetic friction between the sled
and the ground has increased to 0.80. What
is the acceleration of the sled? Explain the
significance of the sign of the acceleration.
f=1300n
m = 1.1 x 10^4 kg
m =0.80
a=?
F=ma
m=Ff/Fn
Fnet= Fx+Fy
ff=0.80 x (9.8)(1.1x10^4)
ff= 86240
86240=(1.1 x 10^4kg) a
a= 7.85m/s2
There are two forces acting on the sled here. One is by the tractor, the other is due to friction. By Newton's second law of motion, the NET force is equal to the product of mass and acceleration.
Fnet = ma.
You've considered only ff in calculating the acceleration.
Also, make sure if you've taken the weight correctly. An 11 ton sled seems like a lot! :eek:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
