Forces and tensions between masses check and help
  • Thread starter Thread starter foonis
    Forces
The discussion revolves around a physics problem involving two blocks connected by a string, with one block hanging off a table. The acceleration of Block B as it descends is determined to be g/2, leading to a calculation of the time it takes for Block B to hit the floor, which is found to be 2√(h/g). The distance between the landing points of the two blocks is calculated using kinematics, with the final answer determined to be 2h. The participants clarify each other's calculations and correct errors related to the height from which Block B is dropped. Overall, the conversation emphasizes the importance of careful algebraic manipulation and understanding of motion principles.
foonis
Two small blocks, each of mass m, are connected by a string of constant length (4h) and negligable mass. Block A is placed on a smooth tabletop as shown, and Block B hangs over the edge of the table. The tabletop is a distance (2h) above the floor. Block B is then released from rest at a distance (h) above the floor at time t=0. Express your algerbraic answers in terms of h, m, and g
∑Fb = ma = Fw - T
∑Fa = ma = T
a) Determine the acceleration of Block B as it descends.
- I came up with acceleration = gravity/2 because after finding the sum of the system of equations above I ended up with a(ma + mb) = mg(Fw) which simplifies to a=g/2
b) Block B strikes the floor and does not bounce. Determine the time it takes for block B to hit the floor.
- I used the equation 2h/g = t² to come up with 4h/(g/2) = t² which simplifies to
2h/√g = t
e) Determine the distance between the landing points of the two blocks.
- I used the kinematics equations X - Xo = Vot + .5at2 and Y - Yo = Vot + .5gt2
and found that the time from Block A leaving the table to hitting the floor was 2h/√(g) and by using that in the equation for movement along the x-axis I found that the distance between the two blocks after landing = h
How does all of this look to you? I feel fairly confident about it I am just not 100% positive.
Thanks!
Hello Foonis
Welcome to Physics Forums!
Sounds reasonable :approve:
2h/√g = t
Something is not right with the above, but I'm not quite sure what. How did the h get out from under the square root? Also, don't forget, Block B is not dropped from a height of 2h, it is dropped from a height of h.
Once again, how did h get out from under the square root?
I came up with a somewhat different answer.
Oh, you're right, I didnt notice that and ran with it. So I plugged it all in again and I got b) 2h/g=t^2 as the base equation to get 2h/(g/2)=t^2 which should simplify to
2√(h/g)=t.
e) I fixed it to end up with the time between the block(a) leaving the table and hitting the floor as 2√(h/g) and by plugging that in my final answer for the distance between the blocks is now √h. How does all of this look now?
∑Fb = ma = Fw - T
∑Fa = ma = T
good.
2h/√g = t
you have a math error in this equation, but the equation itself is not correct. Why did you use g when you already showed that a=g/2?
This is the wrong approach. When the first block hits the floor, the tension force becomes 0 (the string goes slack), but the block on the table continues to move, and then this becomes a parabolic motion problem as the 2nd block leaves the table and lands some distance away from the 1st block.
2√(h/g)=t.
Your equation for the time agrees with mine. :approve:
so far so good. :smile:
Oooh. Something doesn't seem right to me. :frown: You'll need to show your work for this one. How did you find the x-component of Block A's velocity?
Wow this is a tough one haha hmm..
Well I used a kinematics equation to find the velocity as the block slides along the table after the other block hits the ground, which I set up like:
X=Xo+VoT+.5at^2, which i substituded the values to get:
X=0+(0)(2√(h/g))+.5(g/2)(2√(h/g))^2
so
X=.5(g/2)(2√(h/g))^2
so
X=.5(g/2)(4h/g)
so
X=(g/2)(2h/g)
so
X=2h/2
so
X=h?
Im extremely confused about this last one..
Thanks for all the help though, it is really saving me :)
wait could I use the equation Vf = Vi + at ?
im going to try that and see what i get
with that equation I got the velocity of Block A to be (g√h)/(√g)
Am I any closer?
Yes, that's the one. :approve:
'Looks good :approve:
Now you know the velocity in the x-direction (which is constant when the block flies off the table) and the amount of time it's in the air. Solve for distance. :wink:
so then i could just use distance=velocity x time
so
x=((g√h)/(√g))(2√(h/g))
so
x=2gh/g
so
x=2h
So the distance between the blocks after they land is 2h?
'Looks right to me. :approve:
Thanks you helped a ton :D
