Solving Mass from 2 Forces & Force of Impacting Bullet
The discussion focuses on solving physics problems involving forces and motion. In Part 1, the challenge is to find the mass of a body acted upon by two forces of 20 N and 42 N at a 60° angle, with a resulting acceleration of 20 m/s². The correct approach involves using vector addition rather than relying solely on right-angle trigonometry. Part 2 addresses the impact of a bullet with a mass of 6.5 grams traveling at 1150 m/s, which decelerates to rest over 8 cm; the calculated force exerted by the wood on the bullet is approximately -53,726.56 N, indicating the force direction opposes the bullet's initial motion. Understanding the signs in physics calculations is crucial for interpreting results correctly.
omonoid
Part 1
1. The only two forces acting on a body have magnitudes of 20 N and 42 N and directions that differ by 60°. The resulting acceleration has a magnitude of 20 m/s2. What is the mass of the body?2. F=ma3. I am not sure how to solve this because I'm used to being able to use trig like cos and tan, but this problem doesn't create a triangle with 90 degrees
Part 2
1. A bullet of mass 6.5*10-3 kg moving at 1150 m/s impacts with a large fixed block of wood and travels 8 cm before coming to rest. Assuming that the deceleration of the bullet is constant, find the force exerted by the wood on the bullet. 2. F=ma
V^2=Vi^2+2ax
3. V=0 Vi=1150 m/s x=.08 m solve for a and i got -8265625 m/s^2 then multiply by mass (6.5E-3) and get -53726.5625. Is this right? would i void the negative on a force?
Hi omonoid,
omonoid said:
Part 1
2. F=ma
Let me be picky here and say you should write this as Fnet=ma, that is, the sum of the forces equals m*a. Does that help? Have you added vectors together that were not perpendicular to each other?
Part 2
2. F=ma
V^2=Vi^2+2ax
That number looks right to me. The minus sign is showing that the force is in the opposite direction of the initial velocity.
