What is the Correct Force Needed to Slow a Drag Racer with a Chute?
  • Thread starter Thread starter physics114
    Forces Homework
To determine the force needed to slow a drag racer from 203 mi/h to 45.2 mi/h using a drag chute, the problem involves converting speed to meters per second and applying kinematic equations. The calculated acceleration is approximately -19.66 m/s², leading to a force of about -17,259.2 N when using Newton's second law. However, a correction in calculations suggests the net force should be around 17,079 N, with confusion regarding the sign of the force. The discussion highlights the importance of careful unit conversion and accurate application of physics formulas. Overall, the correct force calculation is essential for effective braking in drag racing.
physics114
Correct?
1. Given Problem
A drag racer crosses the finish line doing 203mi/h and promptly deploys her drag chute (the small parachute used for braking).
(a)What force must the drag chute exert on the 878kg car to slow it to 45.2 mi/h in a distance of 199m?
(b)Describe strategy.
2. Formulas
F=ma
vf^2=vi^2+2aΔx
1mi=1609m
1hr=3600s
3. Attempted Solution
b) Strategy
First convert mi/hr units into m/s. Find acceleration by using vf^2=vi^2+2aΔx. Then use the acceleration found and finding Force using Newton's second law.
a) Calculations
Converted
203mi/hr = 90.279m/s
45.2mi/hr = 20.2019m/s
Plug into Motion Equation for Acceleration
(vf^2-vi^2)/(Δx) = 2a
[(90.279)^2 - (20.2019)^2] / [(199m)] = 2a
(408.117-8231.75) / (199m) = 2a
-39.3147 = 2a
a = -39.3127/2
a = -19.6574 m/s^2
Use Newton's Law
F=ma
F= (878kg)(-19.6574m/s^2)
F= -17259.2N
90.279 squared is 8150.3 not 408.117, really not sure what you did there. It should be 8150.3 minus 408=7742, divide that by 199=38.9, divide that by 2= + 19.5 m/s squared
Net force should be 19.5 times the mass (878)= 17,079 N
Thank you =] Made the correction but apparently my answer has the wrong sign? Answer should be in x direction which I thought was what I was finding. Slightly confused =/
Um not sure, Physics confuses me...lol
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
