Forces to push a trolley up a slope
To determine the maximum weight of a trolley being pushed up a 40-degree slope, the relevant equation involves the forces acting on it, specifically F=ma. The maximum force applied to initiate movement is 15N, while 7N is needed to maintain movement. Ignoring friction, the gravitational force acting on the trolley must be calculated using its mass (m) and the angle of the slope. The gravitational force component acting down the ramp can be derived using trigonometric functions. Ultimately, by equating the applied force to the gravitational component, the mass of the trolley can be solved.
rofique2
I'm a Health and Safety advisor having a blonde moment.
Trying to find the equation to use, think it's something to do with F=ma any help please.
A 4 wheeled trolley will be pushed up a slope of 40 degrees and the maximum amount of force that can be applied is 15kg to get it moving and 7kg to keep it moving.
Ignoring friction, What is the max weight that the trolley can be?
I'm going to go ahead and assume you meant 15 and 7 Newtons, not kg, except you also need to know the mass of the trolley, which we'll call m
There are two forces on the trolley, gravity, and the guy pushing. Presumably the guy isn't an idiot and pushes it directly up the incline, but the force of gravity(Fg=mg)acts straight down, so you care about the component of it directed down the ramp, which can be found with trig.
EDIT: Oh haha you're trying to find m
So anyhoo you would take that applied force of 15N, and set it equal to the component of gravity coming down the ramp and solve for m
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
