Formula for delta star in capacitors
To find the equivalent capacitance using delta-star conversion, one can treat capacitors as impedances using the AC impedance formula, which is 1/(jωC). The delta-star transformation can then be applied to these impedances, similar to resistors, and the final impedance must be converted back to capacitance. The discussion highlights the algebraic approach needed to derive the formula for the equivalent capacitance in terms of individual capacitances. It is suggested to eliminate the angular frequency ω early in the calculations to simplify the process. Understanding this conversion is essential for analyzing complex capacitor networks effectively.
avistein
How to find out the equivalent capacitance using delta star conversion?
Delta star conversion formula of capacitors
Using the formula of resistors but not coming.What is the formula of delta star in capacitors?
The slow way to do it is from first principles.
The quick way is to use the AC impedance of a capacitor, which is ##\displaystyle \frac{1}{j\omega C}##, which can be treated like a resistance, then apply the delta-star conversion formula to it and see what you end up with. Remember to convert the final impedance you get back to a capacitance by reversing the formula.
The delta-star transformations work for more than simple resistance - they work for any impedance.
So just convert the capacitances to impedances ... and use the formulas for resistors.
Then convert the impedances back into capacitances.
Hi Curious3141,
quick run down... C1 across b and c, C2 across c and a, C3 across a and b.
I'm trying to derive the formula for Ca in terms of C1, C2 and C3.
If these capacitors were resistances the formula would be Ra=(R2R3/R1+R2+R3) (I think ?)
there for if capacitors.. 1/ωCa=(1/ωC2*1/ωC3)/(1/ωC1+1/ωC2+1/ωC3). (??)
How do I convert this back to capacitance so I just have Ca=...?
Looks like it's just a bit of algebra. Logically, you know that ω should ultimately play no role in the capacitance values you obtain, so it should cancel out along the way. Might as well just eliminate it from the start (or choose a convenient working frequency such as ω = 1). That may make things less cluttered looking.
