I Formula for the large-scale bias of galaxies
The discussion revolves around deriving a specific equation that links the local and global number densities of galaxies with the contrast of dark matter density. The desired relation is expressed as N1 = n1 b1 δDM, where N1 is the local density, n1 is the global density, b1 is the bias, and δDM is the dark matter density contrast. The challenge arises from the existing equation in the referenced article, which includes a term that complicates the direct derivation, specifically the additional mean density term. Participants are seeking clarification on how to manipulate the equations to eliminate this extra term and successfully derive the desired relationship. Assistance is requested to resolve this mathematical issue.
fab13
TL;DR Summary
I would like to infer the relation between the local density of galaxies and the global density in Universe.
From this article : https://arxiv.org/pdf/1611.09787.pdf , I try to deduce the equation that my teacher told me which links 2 quantities :
1) the global number density of galaxies
2) the local number density of galaxies
3) the contrast of Dark matter density
The relation that I would like to find (the relation given by my teacher) is very simple :
##N_{1} = n_{1} b_{1}\,\delta_{\text{DM}}\quad\quad(1)##
where ##N_{1}## is the local number density of galaxies in Universe, ##n_{1}## is the global number density, ##b_{1}## is the bias (cosmological bias of galaxies) and ##\delta_{\text{DM}}## the contrast in dark matter density. When I say "local", I mean in the volume of scale that I consider (in a cluster of galaxies for example, doesn't it ?)
for the moment, I can't find this equation.
Into the article above, they define the bias by doing the relation ##(1.1)## :
##\delta_{g}(\vec{x}) = \dfrac{n_{g(\vec{x})}}{\overline{n_{g}}}-1 = b_{1}\,\delta_{\text{DM}}(\vec{x}) = b_{1}\big(\dfrac{\rho_{m}(\vec{x})}{\overline{\rho_{m}}}-1\big)\quad\quad(2)##
with ##b_{1}## the bias.
As you can see, in this article, authors are reasoning with the contrast of density number of galaxies (##\delta_{g}(\vec{x}))## and the contrast of matter density of Dark matter (##\delta_{\text{DM}}(\vec{x})##).
I tried to modify this equation ##(2)## to get ##(1)## but I am stuck by the following difference : on one side, one takes number densities and on the other one, they take contrasts of density (with contrast density number and Dark matter contrast).
Multiplying the both by the volume ##V## is not enough since there is the value "-1" in the definition of contrast : ##\text{Global Number of galaxies} = \overline{n_{g}}\,V##. I think that I have to use the following relations : ##N_{g}\equiv N_{1}## and ##\overline{n_{g}}=n_{1}## in the relation of my teacher but I am not sure.
Anyone could help me to find the equation (1) from the equation (2) of article cited ?
Regards
Space news on Phys.org
The conversion is in the ##b_1## term which relates the number density contrast to the matter density contrast. I seem to remember this term being called the density bias.
@kimbyd thanks for your quick answer.
Which ##b_{1}## do you talk about ? this of eq##(1)## or eq##(2)##. ?
If I take the relation eq##(2)##, I can write :
##n_{g(\vec{x})} = \overline{n_{g}}\,b_{1}\,\delta_{\text{DM}}+\overline{n_{g}}\quad\quad(3)##
As you can see, ##(3)## is not equal to the equation ##(1)## that I would like to get (since a second term ##\overline{n_{g}}##)
How can I circumvent this issue ?
Any help is welcome, Regards
Given I have exceeded the edit deadline, I just wanted to add at the end of my post above :
With the notations of the equation##(1)##, in order to be coherent, I think that I have to assimilate ##N_{1}## to ##n_{g}(\vec{x})## (local density) and ##n_{1}## to ##\overline{n_{g}}## (global or mean density).
How can I circumvent this issue about the presence of this second term into eq##(3)## compared to eq##(1)## ?
I don't want to be insistent but I really need help about the issue between the eq##(3)## and eq##(1)##, especially how to suppress the presence of the second term of eq##(3)## in order to find equation##(1)##.
Thanks
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Hi, I’m pretty new to cosmology and I’m trying to get my head around the Big Bang and the potential infinite extent of the universe as a whole. There’s lots of misleading info out there but this forum and a few others have helped me and I just wanted to check I have the right idea. The Big Bang was the creation of space and time. At this instant t=0 space was infinite in size but the scale factor was zero. I’m picturing it (hopefully correctly) like an excel spreadsheet with infinite...
