Solving for Average Acceleration: An Automotive Example
To calculate the average acceleration of a car traveling in a straight line, the formula used is \(\bar{a} = \frac{\Delta v}{\Delta t}\). Given the initial velocity of +5.0 m/s and a final velocity of +8.0 m/s over a time interval of 4.0 seconds, the change in velocity (\(\Delta v\)) is +3.0 m/s. Dividing this change by the time interval (\(\Delta t\)) of 4.0 seconds results in an average acceleration of +0.75 m/s². This calculation demonstrates the straightforward application of the average acceleration formula in automotive scenarios.
ganon00
was wondering which formula I would use to solve this equation...
a car traveling in a straight line has a velocity of +5.0m/s at some instant.
After 4.0seconds, it velocity is +8.0m/s. What is it average acceleration in this time interval?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
