The discussion revolves around retrieving data from multiple output files generated by a Fortran 77 simulation related to a chemical model of Titan's atmosphere. Participants are exploring methods to extract specific data arrays associated with chemical names from these files, which contain a significant amount of numerical data.
- Technical explanation
- Homework-related
- Exploratory
- One participant describes the need to extract an array of values for specific chemical names from up to 1000 output files, indicating a lack of familiarity with programming concepts.
- Another participant requests more details about the structure of the output files to provide better assistance.
- A participant outlines the format of the output files, specifying that there are 459 chemical species, each with 124 data points.
- There is a suggestion that the original poster research Fortran commands such as OPEN, READ, and FORMAT to facilitate data extraction.
- One participant inquires about the intended use of the extracted arrays, suggesting that if they are solely for visualization, more modern tools might be preferable.
- Another participant proposes starting with a simpler example file to practice the Fortran commands before tackling the larger problem.
- There is a mention of using command-line tools like grep as an alternative to Fortran for data extraction.
Participants express varying levels of familiarity with programming and Fortran, and there is no consensus on the best approach to extract the data. Some suggest using Fortran, while others propose alternative methods.
Participants have not fully resolved the specifics of the file structure or the best programming practices for data extraction. There are also indications of differing opinions on the appropriateness of using Fortran 77 versus other tools.
