Fourier Transformation Problem
jk89
Hello there! This is my first post, and I've got to say what a great forum you run here. Its helped me out many times before and for that I'm really grateful.
I have a problem with one of the Maths homeworks I've been set. The question has two parts the first part being:
If we have a function f(x) which is defined to be:
-e^(ax) for x<0
e^(-ax) for x>=0
Find its Fourier transformation with
f~(p) = (1/root(2*pi))*integral(f(x)*e^(-ipx)dx) in the limits of infinity and -infinity.
This part i think I've cracked, my answer is:
f~(p)=-(1/root(2*pi))*(2ip/(p^2+a^2)
Now then next step is a bit tricker:
2) Use the theory of Fourier transformations and your answer to the first part to determine the function g(x):
where g(x) is defined to be:
g(x) = integral((p*e^(ipx))/(p^2+a^2)dp) in the limits of infinity and -infinity.
By inspecting the integral i know that the Fourier transform of g(x) is:
g~(x) = p/(p^2+a^2)
However i can't seem to work it back from there any tips would be greatly appreciated but i don't want the full answer(spoils the fun!:smile:)
Cheers!
g(x) is the inverse Fourier transform of the function:
\frac{p}{p^2 + a^2}
Which is the Fourier transform of f, which means that g equals...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
