How Do Lorentz Transformations Confirm a Rocket's Motion in Special Relativity?
The discussion revolves around understanding Lorentz transformations in the context of a rocket moving at speed v in the x direction. The primary equations provided, including ct' and x', define the relationship between the unprimed and primed frames. Participants express confusion about the specific requirements of the homework question, particularly regarding the interpretation of the equations. There is a suggestion that the question may involve expressing the velocity v in terms of the variables γ and β. Clarification on the question's intent is needed for further progress.
Onias
Show that the primed frame corresponds to a 'rocket' frame moving at speed v in the x direction relative to the unprimed frame.
Variables: x, x', t, t', y, y', z, z'
ct' = γct - βγx
x' = γx - βγct
y' = y
z' = z
None, I'm not sure what the question is asking of me!
Welcome to PF!
ct' = γct - βγx
x' = γx - βγct
y' = y
z' = z
Hi Onias ! Welcome to PF! :smile:
(are those equations part of the question?)
I'm not sure what the question is asking of you, either :confused:
I'd have thought that those equations are the definition of the new frame …
unless they're asking you to say what v is, in terms of γ and β
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
