Free Body Diagram Finding Moments
The discussion revolves around solving for forces FGB, FCB, and FGH in a physics problem involving free body diagrams and moments. Participants share equations for summing forces and moments, indicating confusion about the correct application of sine and cosine in their calculations. There is debate over the impact of force FCB and whether the moments calculated about point B are accurate, particularly regarding the perpendicular distances involved. Clarifications are sought on the relationships between forces and their components, emphasizing the distinction between force components and moments. The conversation highlights the need for a solid understanding of the principles of static equilibrium in mechanics.
steve2510
I have to find the forces FGB FCB AND FGH
http://desmond.imageshack.us/Himg696/scaled.php?server=696&filename=img59wa.gif&res=medium
P1 = 5 kN, P2 = 10 kN, JY = 21.25 kN
a1 = 2 m, a2 = 1 m, a3 = 0.5 m, a4 = 1 m, a5 = 2.5 m
Angle FGH makes with the horizontal is: 26.57 degrees
Angle FGB makes with the horizontal is –tan-1(1.5/2)
Sum the forces up and down = 5+10 -21.25 +FGHsin26.57 - FGB sin38.87 = 0Then summing moments =
2x10 - 2 x 21.25 +(a2+a3+a4)FGHcos26.57 + FGB cos 38.87= 0
I don't get what i can do from here and I am a bit stuck and i don't no if the force Fcb would have an effect??
welcome to pf!
hi steve2510! welcome to pf! :smile:
You also have to sum the forces left and right (to equal zero). :wink:
Okay So this is what I've got
ƩFx = Fcb + Fghcos26.57 + Fgbcos-36.87 = 0
ƩFy = 21.25 + Fghsin26.57 - Fgbsin-36.87 -5 - 10 = 0
ƩFy = Fghsin26.57 - Fgbsin-36.87 =- 6.25
ƩMb = (Fghcos26.57 x1.5 )+ (Fgbcos-36.87 x 1) +(2x5) -(2x21.25) = 0
ƩMb = (1.5 x Fghcos26.57 ) + (Fgbcos36.87) = 32.25
ƩMb = (Fghcos26.57 ) + (Fgbcos36.87) = 21.5 (divided by 1.5)
-((Fghcos26.57 ) + (Fgbcos36.87)) = 21.5
= Fcb = -21.5
Am i doing this right at the moment ? I'm not sure if i took moments about the correct point and whether the sin and cos are correct
shouldn't the moment of FGB about B be 0 ? :confused:
and the multiplier of FGH needs to be the distance from B to GH
Am i right in saying Fgb is the force that g exerts on b ? So there would be a moment force in the x direction but not in the y direction as the perpendicular distance would be 0. And i thought 1.5 was the mutliplier as the horizontal force acts along the top of the a4 line
hi steve2510! :smile:
(just got up :zzz:)
but isn't the perpendicular distance zero in any direction? :confused:
i was referring to the cos
Cos is the horizontal component for both forces , am I right ?
you seem to be mixing up the methods for components of force (in a direction) and moments of force (about an axis or point)
cos is for components
this is moments
with moments, it's usually sin :wink:
I'm confused as the sin of both forces don't produce moments around B ? Is there any chance you could write what the sum of the moments is meant to equal
The moment of a force F about a point B is F*d,
where d is the perpendicular distance from B to the line of F.​
If A and C are any points on that line, then Fd = F*AB*sinBAC.
If you're not familiar with this, you need to go back to your book and study and practise it.
okay think its back to the library then, thank you for your help!
