Free-Fall Motion (w/ a tennis ball)
The discussion revolves around calculating the average acceleration of a tennis ball dropped from a height of 4.00m, which rebounds to a height of 2.00m, with contact time on the floor being 12.0ms. The initial calculations indicate that the average acceleration is upward, as the ball rebounds after hitting the ground. However, there is confusion regarding the calculation of average acceleration, with the initial attempt yielding an incorrect value of 525m/s² instead of the correct 1.26 x 10³ m/s². Participants suggest using different kinematic equations to derive the velocities just before impact and just after rebound to accurately determine acceleration. The discussion emphasizes the importance of correctly applying the equations of motion to solve the problem.
Feldoh
To test the quality of a tennis ball, you drop it onto the floor from a height of 4.00m. It rebounds to a height of 2.00m. If the ball is in contact with the floor for 12.0ms, (a) what is the magnitude of its average acceleration during that contact and (b) is the average acceleration up or down?
Equations of motion w/ constant acceleration
I'm pretty sure (b) is up for starters since the ball reaches a height of 2m after it is on the ground which means it's got to accelerate up.
My problem is with part a. I started by figuring out the velocity of the ball the moment it hits the ground.
v = at
v = \frac{y-y_o}{t}
So substituting the second equation in the first one and solving for t:
t = \sqrt{\frac{y-y_o}{a}}
t = \sqrt{\frac{-4m}{-9.80\frac{m}{s^s}}} = .64s
Since I got the time...
v = v_{o}+at = 0 + (-9.80)(0.64) = -6.3m/s
In my mind I thought that I had the initial velocity of the time interval it was on the ground and I thought that the final velocity would be 0 since if it was greater than 0 the ball would be traveling "up".
First I found the time in s and got 12.0ms = .012s, then:
a_{avg} = \frac{v-v_o}{t} = \frac{0-(-6.3)}{.012}
My answer was a = 525m/s^2, but it's wrong -- my book says its 1.26*10^3 m/s^2
So uhh... where did I go wrong? XD
Oh don't think it would really matter at all in this problem but assume there is no air resistance.
How did you get the time? Try using s=ut+\frac{1}{2}at^2 and s=vt-\frac{1}{2}at^2. Then applying v=\frac{y_1-y_o}{t}, find the velocity just before it hits and just after it rebounds, use a=\frac{(v-u)}{t_o}, remembering that one velocity vector points downward and the other vector points upward.
Whoops should have made it a bit clearer how I derived the time. I edited my first post.
But I really don't get what your saying to do...
Well, get two different veocities, by the first three equations, and use the fourth to find your acceleration.
