Free-Fall Physics Homework: Find Velocity After 2s
  • Thread starter Thread starter 5minutes
    Free-fall Physics
A boy dropped a rock from a cliff, and the problem requires calculating its velocity after 2 seconds, ignoring air resistance. Using the equation vf = vi + g∆t, with an initial velocity of zero and gravity as -9.81 m/s², the calculated velocity is 19.6 m/s. The correct answer, according to the textbook, is -20.0 m/s, which accounts for the negative sign of gravity. The discussion highlights the importance of applying significant figures correctly, as 19.6 m/s can be rounded to 20.0 m/s. Understanding these concepts is crucial for solving free-fall physics problems accurately.
5minutes
If a boy dropped a rock off a high cliff, how fast would it be falling after 2.0 seconds had elapsed? (ignore air resistance)
a) -2.0 * 10^1 m/s
b) 2.0 * 10^2 m/s
c) 35 m/s
d) -35 m/s
vf = vi + g∆t
vf = final velocity
vi = initial velocity
g = gravity = -9.81 m/s^2
∆t = change in time
since the initial velocity is zero,
the velocity after 2 seconds is
V(t) = 0 + gt,
V(t) = gt,
V(2) = (9.8 m/s2)(2s),
V(2) = 19.6 m/s
The answer in my book says it is a) -2.0 * 10^1 m/s
How do you get that answer?
If you take g negative, V(2) = -gt.
Apply the significant number rule to get the result.
I'm not too sure on how to apply the signif. number rule; could you please elaborate
19.6 m/s can be written a 20.0 m/s.
