Free Fall Question [ Need Assistance]
To determine the height from which a pile driver should be released to achieve a speed of 20 m/s upon impact, the equation v² = V(o)² + 2ax is utilized, where v is the final velocity, V(o) is the initial velocity, a is acceleration, and x is the position. The calculation initially leads to a negative position value, indicating an error in unit handling. It's emphasized that acceleration can be defined as negative when considering downward motion, which affects the sign of displacement. Additionally, the use of the equation x = V(o)T + 1/2at² is suggested, but time is not provided in the problem. Proper attention to units is crucial for accurate results.
pharmguy
It is desired to have a pile driver strike a pile with a speed of 20 m/s. Assuming the driver to be in free fall, from how high above the pile should be released?
Used v^(2) = V(o)^(2) + 2ax
v=final velocity
V(o) =initial velocity
a=acceleration
x=position
I set up my problem as (20 m/s)^(2) = (0m/s)^(2) +2(-9.8 m/s^(2))x finding position (x).
Next step looks like this 400 m/s^(2) = -19.6 m/s^(2) (x)
Last step looks like (400 m/s^(2))/(-19.6 m/s^(2)) = x
Answer: -20.4 = x
Answer is negative and units are wrong. I believe all the units would cancel out and the answer would be unitless.
I was also thinking about using the equation x=V(o)T + 1/2at^(2) but problem is I wasn't given a time unless I assume time to be 0.
Please Help, Thank You.
Your units aren't quite right, v^2 is (m/s)^2 = m^2/s^2
acceleration is m/s^2, not quite the same thing.
You are free to pick any direction for your acceleration and distance, as log as they agree. If you want acceleration down to be negative, that means displacements down are negative.
ps. Extra marks for checking (and noticing) the units ;-)
Awesome thanks a bunch! Is there a rating system or something somewhere on this site to rate people's help?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
