"Solving Free-Falling Pole Vaulter Problem
  • Thread starter Thread starter Pogorz
Pogorz
A pole vaulter comes down after barely clearing the hurdle. the hurdle is at a height "H" above the top of the soft mat on the floor. The mat has a thickness of "h". when the athlete lands on the mat he slows down at a constant rate so that his speed is 0 just before he hits the ground (suppose the mat can be squeezed to a negligible thickness).
a) Find the speed of the athlete just before he hits the mat.
b) Find the acceleration of the athlete while he is in the mat.
c) Sketch the graphs for y-t, v-t, and a-t.
v^2=vi^2+2ad
I solved for Vf (sqrt19.62H) in terms of H, and for acceleration (sqrt4.905H/h^2)in terms of H and h. it says to 'sketch' a graph, so should i just sketch graphs resembling y=x^2, y=x, and y=9.8 for y-t, v-t, and a-t respectively?
If by "x" you mean time, yes. The vertical position is quadratic in time, the position is linear and the acceleration is constant. However, note that you graph should come in two pieces. One when he is free fall and the acceleration is - g and one when he has hit the mat and the acceleration is ... ?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
