How does the angle of the handle affect the frictional force on the mower?
  • Thread starter Thread starter fishert16
    Force
The discussion focuses on understanding how the angle of the handle affects the frictional force on a lawn mower being pushed at a constant speed. Participants emphasize the importance of drawing a free-body diagram to identify all forces acting on the mower, including the applied force, friction force, normal force, and the mower's weight. It is clarified that the normal force is influenced by the vertical component of the applied force, which is derived using trigonometric functions. The frictional force, which opposes motion, is determined by multiplying the normal force by the coefficient of friction. Overall, the conversation highlights the relationship between the angle of the handle, the forces involved, and the calculations needed to solve the problem.
fishert16
A person pushes a 14kg lawn mover at constant sped with a force of 88N directed along the handle, which is at an angle of 45 degress to the horizontal. (a) draw the Free-body diagram showing all forces acting on the mower. (b) Calculate the horizontal friction force on the mower, then (c) the normal force exerted vertically upward on the mower by the ground. (d) What force must the person exert on the lawn mower accelerate it from rest to 1.5m/s in 2.5 seconds, assuming the same friction force?
F=ma
Fgy= (14)(9.8)cos45
Fgx= Fg sin Theta
Are those correct??
The best I can figure is that each equals the same but I am not sure what the frictional force is. Is it Fgy or Fgx I am just not sure on much.
You've got to first draw the free body diagram and identify all the forces acting and their direction. There's the applied force through the handle, the friction force at the ground opposing the motion, the normal force from the ground, and the mower's weight. Resolve into x and y components and use Newton's laws in each direction.
Well nothing anyone has said seems to help in any . I have the free body diagram drawn and yall try to lead my somwhere i have no prior experience to do.
Than complain on the original thread. Like help still don't get it! People do this all the time and I will call for help if I get stuck.
We are here to do that. Plus there are some good tutorials on this site that supply the concepts needed. So here we go:
think about this hard: if a body is at rest or moving at constant velocity the net forces acting upon it are zero. Now this applies to each dimension. If your lawnmower isn't sinking below your feet, that implies that the forces on it vertically are zero. How can this be? The mower has weight, and on top of that you are applying force downwards thru the handle. Yet is has no movement downward.
So you have m*g (where gee is the earth-surface constant of 9.81m/s^2) and m is th mass expressed in Kilograms. You sit the mower on a scale and it weighs 14*9.8 Newtons. Now the push downwards is partly downward and partly horizontal. You add the vertical component of the component by using trig. Hint Sin (45). The sin is the Y (up/down direction).
Now knowing that you have these two seemingly unopposed forces, but faced with the evidence that the mower just sits on the ground, there must then be a third force, referred to as the Normal force because it acts "normally" ie perpendicular to its own oriebtation. usually earth, so 90 degrees upward.
Oddly enuf, friction does not care about the size or speed (aerodynamic heating etc being an exception) of the object, just the normal force. So you take your results from the above, Normal force, and multiply by the frictional cooeficient.
So now that you have a normal force times the frictional cooefficient that resists movement--yes unless you have a self propelled unit--gotta push. This is the frictional force one has to overcome= N*u.
Now to accelerate you need to provide more push than the resistance. The resistance does not go bigger the harder you push! It stays the same. Be careful here as the harder one pushes at 45 degrees the greater the friction. Does this help?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
