Friction between table and pool ball
The discussion focuses on calculating the force of friction and the coefficient of friction between a pool ball and a table, given the ball's weight and travel distance. The normal force is calculated as 0.1666 N using the ball's weight. Participants suggest using Newton's second law to find acceleration, which is determined to be 0.04272 m/s². The force of friction is then calculated using F=ma, leading to a coefficient of friction (µ) of approximately 0.0436, although one participant suggests an error with a different value of µ around 0.003. The conversation emphasizes the importance of verifying calculations and understanding the relationships between forces.
Drey0287
Assume the weight of a pool ball is .17kg. If the ball traveled 1.2 m in 5.3 seconds, what is the force of Friction and coefficient of friction between the pool ball and the table?
Now, All I know how to do it calculate the normal force which is (9.8)(.17) = .1666 but where do i get from here?
Hints:Use Newton's second law for the rotational motion.(torque is the sum of momenta of all forces).From there u should find µ.The normal force u calculated should be ten times bigger.
I=\frac{3mr^{2}}{5}
Daniel.
I find the acceleration to be 0.04272 m/s^2
Therefore, can you not find the force of friction through F=ma?
F(subF)=(.17kg)(0.04272 m/s^2)
mew=F(subF)/F(subN)
mew=0.007262/0.1666
mew=0.0436
check my work, i may be wrong
mew=F(subF)/F(subN)
mew=0.007262/0.1666
mew=0.0436
My µ approximately equal to 0,003.
Show your reasoning to depict you mistakes.
Daniel.
