What is the coefficient of kinetic friction between the pig and the slide?
  • Thread starter Thread starter B-80
    Friction Slide
To determine the coefficient of kinetic friction between the pig and the slide, one must first calculate the acceleration of the pig on a frictionless incline and then compare it to the acceleration with friction. The problem involves understanding that the initial velocity is zero, which complicates the use of simple formulas. It is essential to analyze the forces acting on the pig by drawing diagrams and applying trigonometric functions to resolve forces into their components. The discussion emphasizes the importance of careful calculations and substitutions to avoid errors. Ultimately, the solution requires a systematic approach to derive the coefficient of friction based on the differences in acceleration.
B-80
A slide loving pig slides down a 40° incline (Fig. 6-24) in twice the time it would take to slide down a frictionless 40° incline. What is the coefficient of kinetic friction between the pig and the slide?
F=ma ; a=(V-Vo)/t ; F=m((V-Vo)/t)
so m((V-Vo)/t) = m((V-Vo)/2t)F(friction)
m cancels V-Vo cancels t cancels which leaves 1/2F(friction) = 1
after solving for F(friction) I get 2, which is wrong, everything cancels pretty much. so I am at a loss
One cannot assume (V-Vo) is the same. If the pig starts at rest Vo = 0. Simply using V / t or 2t doesn't work.
Find the acceleration down the slide without friction, then find the acceleration with friction, and from that determine the coefficient of friction.
Perhaps there is an easier way of doing this problem, but I did it recently and it's a heckofa lot more work than you have there. Here's a clue, this is about the coefficient of friction, and what do you multiply the coefficient of friction with to get friction? You need to start by drawing diagrams and figure out your forces, start calculating...
how can I find either of these, all they gave me was the angle?
Amazingly enough, you can do it. It's a lot of chugging formulas, sines and cosines, solving for certain variables then substituting in other formulas etc. Start simply. Draw the picture of the frictionless slide, then figure out label the forces, split them into x and y, then do the calculations for those forces. You just have to calculate what you can, then keep looking to substitute. And be careful not to mix up sines, and cosines etc.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
