Hi ther, Iam also a person in the virtue of producing a conceptual design in the spherical wheel, the best way to design the car is to look at the audi rsq car. it comes in the movie i-robot and it is a conceptual design of the spherical wheel car, the car has 4 spherical wheels and exactly follows the method of mouse ball rollers for producing motion in the spheres. (ie, one in the x-axis, one in the y-axis, and one in the z-axis on each and every wheel) that becomes 12 output speeds, and each roller has to rotate at diff speed to attain the direction of motion and speed on the balls, so we r going to use 2 gear, 2 motors, connected to a single micro-processor which controls every direction of motion, steering is impossible as far as my knowlegde could search and even it is available the cost is high enough to go off the roof, so the steering for our car is goin to be button system over direction and manual control over accerleration and braking as in normal cars.
The advantages of this concept is 1.Very less power is required to drive the vehicle as contact surface of the balls are minimal and very less force is required to rotate a sphere, 2. Evenly loaded with weight can rotate in all direction remaining inline with the vertical axis of the carried weight and speed of motion, 3. Offers most easy change of direction since it doesn't need to re-align to the movement direction, 4. The anti-over turn funtion of spherical wheels is most advantageous since it doesn't have the stopage of the motion perpendicular to the direction of motion as in the cylindrical wheels, therefore the vehicles can be tall and narrow neglecting the ground clearance and centre of gravity, 5.Sphere wheels can work oblique till 15 degrees 6.Due to its shape,the sphere cdan surmout obstacles from any position,both front and lateral, instead of the traditional wheels which cannot the latral obstacles. 7. Spherical wheels can easily move because each wheel cahnges its directoin independently of the other ones. 8.Very less friction over wheel and road so greater speeds with less power. Disadvantages: 1. Control over slopes is difficult, 2. Irregular sphere can cause problems which can happen due to the irregular contact surface over the roads when in motion. 3. Less friction therefore very diffucult when braking (ABS) 4. When traveling in one direction only one rollers of the three in use, for ex. traveling in forward motion uses only the x-axis rollers, but all the other rollers are also in contact, this reduces the friction between the rollers and the balls which is the essence of frictional drive in this concept and the shape of the ball becomes irreglar easily, this is my concept and iam dying to suceed so any of u brainstroms out there read this reply, give us some thoughts...l
